Activity › Forums › Apple Final Cut Pro Legacy › Dreamcolor Calibration
Posted by Bjarki Gudjonsson on June 4, 2010 at 9:33 amHi guys.
I’ve had a DreamColor and HDP2 set up for a couple of months now and they work very well. However I just received my HP DreamColor Calibration Kit. Having upgraded my monitor’s firmware from a PC via USB without a hitch, the calibration software constantly says I have to connect a USB cable from my computer to my monitor. I’ve tried different cables and different computers (PC and Mac) but no dice. Any ideas?
BjarkiNeil Redman replied 12 years, 11 months ago 10 Members · 63 Replies -
Jeremy Garchow
June 4, 2010 at 1:38 pmThere’s a USB service port under the monitor next to the power switch. Use that.
Jeremy
Bjarki Gudjonsson
June 4, 2010 at 1:57 pmI did. It’s all set up correctly. I’m thinking it’s a monitor defect.
Jeremy Garchow
June 4, 2010 at 2:05 pmSo you have a USB cable from the service port back to your computer, the calibrator coming out of the USB hub on the right side of the monitor and dvi to your computer?
Also I should mention, that splash screen comes up no matter what. When you start the calibration process and the software allows you to select the Dreamcolor (instead of just a generic LCD monitor) then you’re all good.
Jeremy Garchow
June 4, 2010 at 2:42 pm[Bjarki Gudjonsson] “Correct.”
Did you read the second part? Here it is again:
“Also I should mention, that splash screen comes up no matter what. When you start the calibration process and the software allows you to select the Dreamcolor (instead of just a generic LCD monitor) then you’re all good.”
Bjarki Gudjonsson
June 4, 2010 at 3:03 pmSorry. That comes up. But after I select the DreamColor in the APS, it tells me to connect the USB which is already connected.
Jeremy Garchow
June 4, 2010 at 3:06 pm[Bjarki Gudjonsson] “it tells me to connect the USB which is already connected.”
And it doesn’t let you go further?
Jeremy Garchow
June 4, 2010 at 4:00 pm[Bjarki Gudjonsson] “No, it always claims the USB is not connected.”
What version of the software are you running? Make sure to download the latest from XRite as it’s Snow Leopard compatible, it’s v1.1.
Jeremy
Jeremy Garchow
