Activity Forums Broadcasting DPS 475/575 Framesync Question (UPGRADE VS. OPTIONS)
  • DPS 475/575 Framesync Question (UPGRADE VS. OPTIONS)
    Posted by Jan Janowski on January 12, 2019 at 12:43 pm
    I’ve 2 DPS Framesyncs: a 475 and 575….
    475 is Presently used in a VHS Restoration system, using SVideo or Composite intputs… 575’s power supply presently being repaired…
    The 475 has Version 1.5 Firmware and Boot G with both the Audio Hardware (XCV300) and DNR Paid Option…
    There is a known issue where the Composite and SVideo inputs are slightly degraded in this Firmware Version, that is fixed in G2.16 update… From the Update Notes (That I realize say 2.14, but it’s from the 2.16 Upgrade Notes!:
    Version G2.14 and H2.14 DPS-475/575 firmware package
    • Fixed problem where S-Video input would clip to quickly and causes data overflow and bad video output.
    • Added +6 dBu to the Audio Op Out Level Parameters.
    • Increased noise handling for composite video input.
    • Corrected the problem (No.177) which caused 100 lines of displacement in PAL..
    Obviously this would be a good thing for any VHS Restoration!!!
    My Question….. Does anyone know for certain if the OPTIONS remain AFTER a Firmware Update????
    (In My Case: Audio H/W=300 Series, and more importantly, Digital Noise Reduction OPTION — Which I do not have the unlock codes for, if they get erased!)
    I know this is an old unit, but for VHS Restoration good captuer’s are necessary!!!
    Thank You for your Posts!!!
    Christos Gartaganis replied 6 years, 8 months ago 3 Members · 23 Replies
  • 23 Replies
  • Irving Moy
    January 13, 2019 at 1:32 am
    Hi Jan,
    I also have a DPS 475 frame sync/TBC that I use to digitize VHS.
    I turned it on today and I get this message in the display:
    DPS Boot EPROM rev.G
    No loadable firmware.
    I bought the 475 used, so I do not have a copy of the firmware to re-flash the firmware.
    May I ask where you found the firmware, since Leitch was purchased by Harris and they don’t seem to be supporting the 475?
    I might be able to answer your questions about options since I will be probably upload the firmware more than once to see if there is an issue with the EPROM.
  • Jan Janowski
    January 13, 2019 at 12:54 pm
    I was told that the email for the company that last had information on 475/575 is:
    insidesales@imaginecommunications.com I am awaiting information from them on a request I sent earlier last week .
  • Jan Janowski
    January 14, 2019 at 1:53 pm
    If you want to discuss this more, contact me offline
  • Jan Janowski
    January 14, 2019 at 3:33 pm
    Oh by the way, an “Engineer” replied from that email….. (Forwarded to him by sales) and his answer was short and sweet:
    “Hi Jan, the DPS product is end of life (EOL) for a while. There is no support for this product.
    Thank you,
    Haydee”
    Post your email address or contact me offline
  • Jan Janowski
    January 14, 2019 at 5:27 pm
    V2.16 can be installed without losing Options
  • Irving Moy
    January 14, 2019 at 9:40 pm
    Thanks for all the information!
    I’m glad to hear that your question about upgrading has been answered.
    I did find the v2.15 and v2.16 firmware, plus the Windows uploader program. I tried to upload the firmware to the DPS but the computer could not connect to the DPS. That was disappointing but not surprising since the DPS could not load the firmware from the EPROM. That means the DPS had no operating system running in RAM that could respond to the uploader program.
    I suspect that either the EPROM has failed or the circuitry that reads the EPROM has failed. I read on another forum that there is no one left that services these frame syncs. Even if I manage to replace the EPROM, I have no reasonable way to load the firmware onto the new EPROM, so the DPS is effectively dead.
    I see other used DPS 475 units for sale on eBay but I am hesitant to spend more money on another unit that may also suddenly fail. I’m instead thinking about renting an AJA FS1 since the company is alive and well and the FS1 is still a current, supported model. I’ve been impressed by all the AJA products I’ve used so I may eventually take the plunge and outright buy an FS1.
  • Jan Janowski
    January 14, 2019 at 9:51 pm
    did you try the trick indicated in the “Release Note” document…. Hitting the Enter Key during bootup, to put boot cycle, that puts unit into low level download mode…. ??
    I don’t know if this will help, but at this point, what do you have to lose?
  • Irving Moy
    January 15, 2019 at 7:40 am
    Thanks for the tip! I tried it several times and still got the “No loadable firmware.” message on the front panel display. Then I tried the other Power-Up Keys as described in the Service Manual. The BYPASS button did trigger the self-test but the MEMORY and KEYER buttons did not trigger their power-up functions. On the fourth or fifth cycle of trying all the power-up buttons, the ENTER button did trigger the “Download firmware.” message. I ran the firmware uploader on the PC but it still could not connect to the DPS.
    This time I remembered to check if the serial cable needed a null modem, so I dug out the RS-232 tester and sure enough, the RX line was active instead of the TX line. I plugged in a null modem adapter and the uploader program was able to connect. But the upload failed and the DPS front panel display showed 0% loaded because there was not enough space in memory for any uploads.
    Since holding the KEYER or MEMORY buttons at power-up did not trigger the delete firmware or wipe memory functions, I don’t see a way to make room in the EPROM for an upload. So it still looks like there is a problem with correctly accessing the EPROM.
  • Jan Janowski
    January 15, 2019 at 12:43 pm
    Use a 9 pin straight through cable….
    Also, I had to go into device manager/ports/advanced and reduce the buffer speeds to nearly minimum at 9600 baud to stop it from failing on serial upoad…
    Though it does seem that your Eprom is DOA… Hey! We Tried!
  • Irving Moy
    January 15, 2019 at 8:44 pm
    I was using an old serial cable that had DB9 connectors on both ends, so it probably was a null modem cable used to transfer data between computers before Ethernet networks became the norm. Adding the null modem adapter unswapped the TX and RX lines.
    The upside to the DPS failing is that it caused me to do a more detailed search for frame synchs for use in a VHS digitization workflow. I found the Ensemble Designs BrightEye series. The BrightEye 3’s description explicitly mentions its use with VHS decks and the BrightEye 75 has embedded audio, which would make it a drop-in replacement for my DPS. I asked the manufacturer if the BrightEye 75 is compatible with VHS decks and they said yes, it would be better than the BrightEye 3.
Page 1 of 3
