Activity › Forums › DaVinci Resolve › Don’t update to 10.7.4 yet if running GTX5xx cards
  • Don’t update to 10.7.4 yet if running GTX5xx cards
    Posted by David Pirinelli on May 10, 2012 at 1:07 am
    There should be a new “Web Driver” posted by Nvidia shortly, don’t update before you hear about this and CUDA all working together.
    Robert Due replied 13 years, 8 months ago 12 Members · 15 Replies
  • 15 Replies
  • Clark Bierbaum
    May 10, 2012 at 1:33 am
    Thanks for the heads up, David!
    BTW – If you need a card David is the MAN. Helped with some issues and now my system ROCKS!
    Thanks Again!
    Clark
    Clark Bierbaum
    Colorist, Contractor, Realtor
    Charlotte, NC
  • Juan Salvo
    May 10, 2012 at 1:49 am
    Wonder if well get support for 600s? Thanks for heads up David.
    Online Editor | Colorist | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Victor Hammer
    May 10, 2012 at 8:03 am
    I already did and now I have a black screen! how do I go back to the earlier version!
    Thank you
  • David Pirinelli
    May 10, 2012 at 8:44 am
    Give me a few minutes, I am going to try to fix the driver kext.
    OSX 10.7.4 breaks the “MAGIC ” support.
    I have a feeling that Nvidia will release new drivers for 10.7.4 soon, but until then I will figure out and post a fix.
    EDIT: OK, here is a quick fix. This will enable the driver to include GTX570 and GTX580.
    I will do one for GTX560 later on.
    If you were using the “”self init” feature, you will also need to install ATY_Init from Netkas.
    If you had one of our EFI cards, this should do it by itself.
    You will need to use Kextdrop or Kexthelper to install this once you unzip it.
    4109_nvdagf100hal.kext.zip
    If you are using an EFI card, you will have one screen still functional to “see” from while you install this. If you were using the “Magic” feature, the card will be black as night until you install this fixed next AND ATY_Init.
    If you were using Magic Drivers to run a GTX4xx card, you don’t need this fixed kext, just ATY_Init.
  • David Pirinelli
    May 10, 2012 at 5:16 pm
  • Esteban Aguilera
    May 11, 2012 at 8:45 pm
    Anyone has tested, is very curious because 10.7.4 in mbp runs super fast, first time it does with lion.
    with the last nvidia drivers is again everything working ok ?
    Di Davinci Resolve Colorist
  • Ralf Kleinermanns
    May 13, 2012 at 2:00 pm
    Even with Nvidias latest driver update 10.7.4 broke OpenCL support for Nvidia cards.
    I downgraded to 10.7.3 from TimeMachine backup -> Apple mail stuck while (forced) re-import of my mails, so I had to rebuild my 10.7.4 system from the backup I did before downgrading. Thanks Apple: great user experience! 🙁
  • Sascha Haber
    May 14, 2012 at 11:06 am
    Yep, they are getting better and better for pro users .
    A slice of color…
    DaVinci 8.2.1 OSX 10.7.2
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    ICA Instructor
    https://www.icolorist.com/Sascha.html
  • David Pirinelli
    May 14, 2012 at 8:50 pm
    The OpenCl fix is pretty much same as before.
    On front page of Netkas.org
  • Jon michael Puntervold
    May 16, 2012 at 8:47 pm
    So does the new nVidia drivers get back the same magic functionality as in OSX 10.7.3?
    I’ve got a new Mac Pro waiting to get set-up, and a GTX 580 in the mail…
    BTW: How is it with the 6-pin mini power connector to 8-pin plug. Any suggestions for a nice cable?
