Activity › Forums › Adobe Premiere Pro › Does Premiere allow audio replacement without affecting video?
  • Does Premiere allow audio replacement without affecting video?
    Posted by Danny Mulen on January 25, 2012 at 3:04 am
    Is there any program out there that can easily and quickly swap audio on an MP4 that I spent hours rendering without having to re-render the video? I don’t understand why this isn’t an easy option if audio and video are separate things.
    I had an mp3 as the audio track for a music video and now the client sent a “mastered” version of the audio so I need to replace it in place.
    Petros Kolyvas replied 14 years, 8 months ago 3 Members · 4 Replies
  • Paul Neumann
    January 25, 2012 at 3:26 am
    -Import the new file to your project
    -Highlight the audio to be replaced in the timeline
    -Alt/Option drag the new clip onto the highlighted clip in the timeline
    -Green + appears
    -Drop the clip to replace in place
  • Petros Kolyvas
    January 25, 2012 at 4:02 am
    Hi Paul,
    I believe he means re-muxing new audio without affecting/transcoding the video.
    QT Pro could/can do this (though it wasn’t totally straighforward), and there are tons of Windows/Linux Tools available (MP4Muxer is one.)
    There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger
  • Danny Mulen
    January 25, 2012 at 3:07 pm
    Yes I ask because I dont want to spend another 5 hours re-rendering just to change the music (it’s the same exact song, just a more cleaner version suited for the video).
  • Petros Kolyvas
    January 25, 2012 at 3:56 pm
    Hi Danny,
    What platform are you on?
    One good idea, in the future, is to export a “Master Version” (something in either Uncompressed, Cineform, ProRes, DNxHD, AVCIntra, Etc.) so you can make changes like this quickly when you need to export multiple highly-compressed copies, or make changes. If you export to a codec like that, you only need to spend the time it takes to encode to MP4, and not re-render the whole thing. Just a thought/unsolicited advice… take it for what it is.
    However, if you are on Windows (or have access to Boot Camp/Parallels/Fusion) MP4Muxer will do the trick.
    https://www.dvbportal.de/projects/mp4muxer/
    While I’m predominantly an OS X user, I don’t know of any really good tools to do this on the Mac side of things.
