Activity Forums Adobe After Effects Digital Anarchy New Products: ReSizer 2.0 and Chaos Stock vol. 2
  • Digital Anarchy New Products: ReSizer 2.0 and Chaos Stock vol. 2
    Posted by Jim Tierney on April 20, 2006 at 1:29 pm
    Two announcements on the After Effects front:
    Chaos Stock vol. 2: Royalty free SD and HD backgrounds + After Effects project files
    Volume 2 contains 21 motion backgrounds (HD version has 18 bgs) that not only come as pre-rendered QuickTime movies, they include the complete After Effects 6.5 project file. No third party plugins are needed, just those that come with the Production Bundle. This gives you the ability to modify the project and create something that doesn’t look like stock footage in a fraction of the time it would take to create something from scratch.
    Take a look at the footage and download a sample project:
    https://www.chaosstock.com/vol02/footage02.htm
    ReSizer 2.0, Upconvert from SD to HD
    ReSizer 2.0 provides algorithms for intelligently upconverting footage and scaling images. This gives you great flexibility in the way that you scale images in After Effects and Final Cut Pro.
    The plugin produces exceptional results, regardless of whether you’re up-converting from SD to HD, web video/podcasts to SD, or zooming in 800%. Multiple algorithms are used to accurately increase the resolution of your original image. A De-Interlacer that uses time estimation algorithms (optical flow) is built-in to produce cleaner original frames from SD footage.
    To get a demo and more info go to:
    https://digitalanarchy.com/resizer/resizer_main.html
    Come check out a demo of both at our NAB booth, SL5138-F in the Plugin Pavilion (right next to Adobe). We’ll be hanging out with all the rest of the plugin delinquents…
    Jim Tierney
    Digital Anarchy
    http://www.digitalanarchy.com
    415-586-8434
    Jim Tierney replied 20 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
