Activity › Forums › Apple Final Cut Pro Legacy › Difference In exporting Quicktimes
  • Difference In exporting Quicktimes
    Posted by Espnetboy3 on March 3, 2006 at 7:09 pm
    Hey all. I have been having some issues with exporting my rendered footage. Basically I have noticed that everytime I choose File>Export>Quicktime movie that whatever codec or compression i choose the final result is a FCP video file. Usually these always play smooth and work in fcp. I can also choose the default to make it a pure quicktime file. The other is File>Export>Using Quicktime conversion. When these finish exporting the file is automatically a quicktime file icon and not a fcp. They both basically have the same options and ot he same thing so what is the difference between the two? Thanks
    Tom Wolsky replied 20 years, 6 months ago 3 Members · 4 Replies
  • Matthew Brunn
    March 3, 2006 at 8:32 pm
    There is a tag in the header of the file that associates it with FCP instead of QT. Open the file in QT and save as a different name. It should change the association.
    Hope this helps-
    Matthew
    Quad 2.5 G5
    OSX 10.4.X
    Ram 4GB
    FCP 4.5/AE 6.5/DVDSP3
  • Espnetboy3
    March 3, 2006 at 11:04 pm
    So basically they do the exact same thing and mean no difference? Thats kind of weird isn’t it? I figured one would be more beneficial for saving clips that will be brought back to fcp. Meaning like when u reimport you wont have to re render.
  • Espnetboy3
    March 9, 2006 at 4:51 am
    SO I still dont understand why there are two diff exports to quicktime conversions. Do people just use either or?
  • Tom Wolsky
    March 9, 2006 at 1:25 pm
    QuickTime Movie can be made to do other things, but it is specifically designed to create a file without recompressing the video. You can’t do that with QuickTime Conversion; it always recompresses even if the settings are identical and it loses the timecode track. A QuickTime Movie file has KeyGrip as the creator type (Final Cut’s original creator type) and may not be recognized in some application and certainly not on PCs. If you need a universally recognizable QT file you need to use QuickTime Conversion or run it through the QuickTime Pro player.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
