Activity Forums Apple Final Cut Pro Legacy DESPERATE HELP NEEDED
  • DESPERATE HELP NEEDED
    Posted by Alexander Gao on January 16, 2006 at 9:45 pm
    I shot some test footage in 16:9 progressive on a sony DCR-TRV900. Now, I know it’s truly only 15fps, but when i export using compressor to MPEG-2, the video looks terrible, nothing compared to what it was in the timeline. It looks kind of like if i set the timeline to half quality. What am I doing wrong? When i export to animation quicktime, it looks just fine.
    Alexander Gao
    “When the revolution happens, I’ll be leading it.”
    Alexander Gao replied 20 years, 3 months ago 2 Members · 2 Replies
  • David Bogie
    January 16, 2006 at 10:44 pm
    Your desperation is preventing your from posting sufficient information. Take a deep breath and try to think about what we need to know before we can help. Here are few questions you might think about answering for us:
    What’s your target output?
    Why did you shoot it at 15fps progressive?
    What MPEG2 settings did you use in Compressor?
    Why are you using Compressor?
    Why have you chosen this route without knowing what you were doing?
    What is your backup plan in case there is no viable solution?
    bogiesan
  • Alexander Gao
    January 17, 2006 at 12:35 am
    bogiesan
    Ok, so. My target output is DVD (MPEG-2 needed first, of course). I shot it at 15fps progressive because I am using a DCR-TRV900 and the progressive mode gives much better image quality, but it only records 15fps and then doubles all of the frames to simulate 30 frames. I am using compressor because i want to end up with an MPEG-2 to burn onto a dvd in dvdsp 4. I chose this route because I thought i kne what i was doing, but honestly have never worked in prog. mode before. My backup plan was to come too creativecow in case I ran into trouble. Ok, so now do you have any suggestions for me as to why my output is getting so poor in qulaity when i go from fcp straight to compressor, and why it looks GREAT in the timeline, but horrible as MPEG-2??? (My settings in compressor were 90 min best DVD, 16:9, and this loss of quality occurs no matter what dominant field I choose. Bottom, top, progressive, OR automatic).
    Alexander Gao
