Activity Forums Adobe After Effects Delivering a job in NTSC & PAL.
  • Delivering a job in NTSC & PAL.
    Posted by Andrew on October 27, 2006 at 7:15 pm
    Help,
    My client will be requesting a master elememts reel in both NTSC & PAL, is it as simple as just going to a conversion facility to make a dub? Or would I have to recreate all my comps to work with PAL?
    Thanks!!
    Andrew
    Sam Moulton replied 19 years, 11 months ago 2 Members · 4 Replies
  • Sam Moulton
    October 27, 2006 at 10:49 pm
    a dub from a good machine costs about 50 bucks and always looks great. I think it’s the most efficient and best looking way to from ntsc to pal or pal to ntsc. you can do the job in ae, but it takes some testing, some levels and color work which is seldom mentioned, and some fussing with the interlacing. i’d rather spend the 50
  • Andrew
    October 27, 2006 at 11:03 pm
    thanks. David & Sam
    I actually did look in the common questions section but was sure it provided the right solution for my needs.
    I am gonna have a ton of comps to render..
  • Andrew
    thanks. David & Sam
    I actually did look in the common questions section but wasnt sure it provided the right solution for my needs.
  • Sam Moulton
    October 27, 2006 at 11:24 pm
    id make your projects pal then have a post house convert them to ntsc. scaling down is always better
