Decklink Studio driver/firmware issues with OSX 10.5.8 and FCP 6.0.6
I updated to the v7.9.3 drivers and firmware on a Decklink Studio 2 and have encountered an audio monitoring issue during capture in SD, haven’t tried HD yet.
While capturing into FCP 6.0.6 with the Blackmagic NTSC 10bit settings, the audio sounds like it’s registering the SDI embedded audio signal and sending that out instead of the analog audio. In other words, all you hear is digital garble while monitoring analog audio but the capture is fine after wards and plays back without issue.
I back rev’d the drivers but 7.8.1 but the problem persists. I think the firmware update after I loaded 7.9.3 may have hosed the capability to monitor analog audio properly during capture for my setup. Has anyone seen this or does anyone know of a way to back rev the firmware from the 7.9.3 update? I am going to try going back to 7.7.3 as one of the packages must force a firmware update on the card.
Thanks in advance for any insight that anyone might have on this.
