Activity Forums Adobe Premiere Pro Dealing with Color Shifts: AE comps brought into Premiere Pro
  • Dealing with Color Shifts: AE comps brought into Premiere Pro
    Posted by M. Bernard on January 26, 2015 at 8:41 pm
    Any suggestions on how to bypass, or properly set, the color space in After Effects, for AE comps I bring back into Premiere Pro, that appear to have a color shift?
    I finished and color graded a project entirely within Premiere Pro (using Red Giant Colorista II and Magic Bullet looks), but have had to reopen the project and bring parts of it into After Effects to apply motion and transitions between clips. I can’t figure out a workflow, or the appropriate AE color space to use within AE ‘Project Settings’, that allows me to avoid the color shift when an AE comp is brought back into Premier, ie via dynamic link comps or an imported PP project into AE..
    Regrading the affected segments is an option, but I was hoping to avoid that and figure out a good game plan for the future.
    The closest match seems using sRGB IEC61966-2.1 with only Linearize Working Space selected, but there appears to be a tint and gamma shift going on.
    I followed this example for forcing the dynamically linked AE comp to output a comparable look back into the PP project ( https://forums.creativecow.net/thread/2/1052523 ) but the difference is I graded within PP, not in an AE RGB space, and applying the Color Profile Converter and enabling display settings on an adjustment layer did not help.
    Apologies for what must be my rudimentary knowledge of color spaces and color processing between platforms..
    Thank you!
    Matt
    Premiere Pro CC 2014
    After Effects CC 2014
    Mac OS X 10.9.5 (13F34)
    21.5-inch, Mid 2011
    Processor 2.8 GHz Intel Core i7
    Memory 12 GB 1333 MHz DDR3
    Graphics AMD Radeon HD 6770M 512 MB
    Tom Slemmons replied 10 years, 2 months ago 3 Members · 2 Replies
  • Chris Wright
    January 27, 2015 at 8:31 pm
    the Color Profile Converter won’t work unless you precomp it. also view-simulate might be on
    there’s 16-235 and 0-255 rec.709.
  • Tom Slemmons
    July 15, 2016 at 9:15 am
    I’m having a very similar problem right now. Did you ever find a solution?
