Activity › Forums › DaVinci Resolve › DaVinci, Premiere Pro and the Nvidia GT 120 and the quadro 4000
  • DaVinci, Premiere Pro and the Nvidia GT 120 and the quadro 4000
    Posted by Jose Arce on April 24, 2012 at 4:50 am
    Hi, I have in my macpro 2008 the quadro 4000 and work fine with the adobe suite, Now I’m just starting to use and abuse DaVinci Resolve, but for the minimal expecification need other card. I going to purchase in Ebay the GT 120, this configuration works fine with boths program?
    Somebody write once you installed the gt120, premiere don’t recognize the quadro 4000 for the cuda and the open GL aplications. That is true?
    Thanks.
    Colin Travers replied 14 years, 4 months ago 7 Members · 17 Replies
  • 17 Replies
  • Juan Salvo
    April 24, 2012 at 4:52 am
    I answered in the other forum as well, so this is double posted.
    Premiere cs5.5 and under needs to be connected to the card to benefit from it. However this may change in cs6. If you dont need killer speed you can use davinci with just one card.
    online editor | colorist | VFX | BD author
    https://JuanSalvo.com
  • Jose Arce
    April 24, 2012 at 5:12 am
    Ok, Thanks.
  • Margus Voll
    April 24, 2012 at 6:37 am
    You will not get any satisfactory speed i bet with relatively slow machine combined with not so fast gpu.
    Just saying that you do not have any hi expectations.
    You may as well need special 4000 and 120 from here:
    https://www.ebay.com/itm/Nvidia-GT120-for-2008-up-Mac-Pro-Dual-DVI-DaVinci-Resolve-Runs-2-30/230736283229?ssPageName=WDVW&rd=1&ih=013&category=3762&cmd=ViewItem#ht_1536wt_1324
    Ask David Pirinelli about it
    https://my.creativecow.net/David-Pirinelli
    Margus
    https://iconstudios.eu
    DaVinci 8.2.1 OSX 10.7.3
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
  • Sascha Haber
    April 24, 2012 at 10:22 am
    Keep the 4000 as primary card, get a any 470 as secondary card and a Y-cable.
    Perfect in-the-box solution
    A slice of color…
    DaVinci 8.2.1 OSX 10.7.2
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    Extreme 3D+
    ICA Instructor
    https://www.icolorist.com/Sascha.html
  • Jose Arce
    April 24, 2012 at 2:09 pm
    What kind of Y cable you recommend for the 470.
    I still have my old ATI HD 4870, I think I need only for my monitors, and the other card for the CUDA process in Premiere and DaVinci.
    Or if better buy the 470.
    I read from other post the Y cable made some issues in the motherboard.
    DaVinci Resolve 8.2
    MacPro 3,1
    2x 2.8 Quad-Core
    14 gb RAM
    Quadro 4000
    6T RAID
  • Margus Voll
    April 24, 2012 at 2:39 pm
    I made my own Y cable and no issues.
    Just had extra cable and did cut this in half and soldered this to second cable.
    Now i have 4000 and 470 running in one machine.
    Really neat setup.
    Margus
    Multibridge 2 Pro
  • Colin Travers
    April 25, 2012 at 1:25 pm
    I have a 285 and a 470 lightly used for sale if interested let me know..
    DaVinci 8.2 OSX 10.7.3
    MacPro 12-core 5,1 2.66 Ghz
    32GB RAM x4 8GB
    Software RAID 0 (8TB Internal)
    Nvidia GT120/GTX580
    BMD Extreme3D
    HDlink3D DisplayPort
    Dreamcolor/Panny VT25
    Tangent Wave / Wacom
  • Mel Feliciano
    April 25, 2012 at 10:24 pm
    Hi Jose, I noticed you posted the same question at “Adobe Premiere Pro” and “Adobe After Effects Expressions” forums. You got some response here but nobody has really answered your question yet.
    My situation is similar to yours. I have a 2009 Mac Pro (4,1) with the original GT-120 and was thinking on adding a quadro 4000 to get maximun acceleration with the Adobe Mercury Engine. This is going to be a multi-purpose workstation running also Davinci Resolve. This is an ideal setup as per Blackmagic Desing recommended configurations. What you and I want to know is if there is going to be any conflict with Premiere Pro not recognizing the quadro 4000 card because of the GT-120.
    I’m eager to know the answer to this and hear about any user experience with a similar setup. I wonder if you can tell Premiere Pro to use the quadro 4000 and ignore the GT-120.
  • Juan Salvo
    April 25, 2012 at 10:29 pm
    [Mel Feliciano] “What you and I want to know is if there is going to be any conflict with Premiere Pro not recognizing the quadro 4000 card because of the GT-120”
    As I responded to Jose, the answer is yes. Premiere as of CS5.5 can only use the card the display is connected to for MPE. Resolve, can’t use the card the display is connected to for processing. So you’re damned if you do and damned if you don’t.
    The best solution is as Sascha proposed. Y-split for power, and a GTX470 + Quadro 4000, this would allow you to hve the quadro for MPE connected to monitor & the 470 unconnected to any display for DaVinci.
  • Mel Feliciano
    April 25, 2012 at 11:20 pm
    So what you’re saying is that Resolve won’t work if there is a monitor connected to the GPU that will do the heavy processing, in this case the quadro 4000. And Premiere Pro has the opposite behavior; it requires the GUI monitor to be connected to the same GPU that accelerates the Mercury Playback Engine.
    Ok, now I get it. Thanks!
