Activity › Forums › DaVinci Resolve › DaVinci, Premiere Pro and the Nvidia GT 120 and the quadro 4000
Colin Travers replied 14 years, 3 months ago 7 Members · 17 Replies
Jose Arce
April 26, 2012 at 2:06 amWell thanks.
Now I need to find the 470 and try to arm a Y split.
Or if I lucky enough buy other quadro 4000, but for the price I going to the first option, My only fear is not fried my motherboard.
Colin Travers
April 26, 2012 at 1:20 pmI have a slightly used 470 from Dave P. if you are interested?
DaVinci 8.2 OSX 10.7.3
MacPro 12-core 5,1 2.66 Ghz
32GB RAM x4 8GB
Software RAID 0 (8TB Internal)
Nvidia GT120/GTX580
BMD Extreme3D
HDlink3D DisplayPort
Dreamcolor/Panny VT25
Tangent Wave / Wacom -
Margus Voll
April 26, 2012 at 1:39 pmWhat i did i took 3 cables and made one of those Y.
1 you use as you do now but second and third i soldered from the middle to be Y.
So cables 2 and 3 i did cut in the middle and got rid of one start point of cable.
Then i soldered start point of the cable (motherboard side) with two end points.If you know how to solder it takes you 10 minutes.
For me it was fastest and neatest option as final setup was relatively clean, no loose
cable endings etc.—
Margus
DaVinci 8.2.1 OSX 10.7.3
MacPro 5.1 2×2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro -
Sascha Haber
April 26, 2012 at 4:40 pmMy Q400, GTX 470, Decklink or Aja Kona 3, eSaya card and 5 WD black caviar drives together draw 450 watt.
No probs with the internal PSUA slice of color…
DaVinci 8.2.1 OSX 10.7.2
MacPro 5.1 2×2,4 24GB
RAID0 8TB
Extreme 3D+ICA Instructor
https://www.icolorist.com/Sascha.html -
Diego Delanoe
May 21, 2012 at 5:19 pmDoes anyone knows yet if the problem got solved in CS6???
THE PANIC PROPAGANDA
Diego Delanoe
May 21, 2012 at 5:23 pm¨I have a slightly used 470 from Dave P. if you are interested?¨
Colin, how much are you asking for the 470?
have you found another configuration that works better fot Davinci/adobe GPU functionality?THE PANIC PROPAGANDA
Colin Travers
May 21, 2012 at 5:34 pmHey Diego,
I am asking $300 for the 470 Dave P flashed for mac card. I have not tried to utilize the GPU accelerated stuff with the Adobe CS suite – definitely hope in CS6 it will just see my GPU only card even though monitors are not attached to it!
DaVinci 8.2.1 beta2
OSX 10.7.4 (SSD in second optical bay)
32GB RAM x4 8GB
Nvidia GT120/GTX580 (CUDA 4.2.7)
Decklink Extreme3D
FSI LM-2461W / Panny VT25
