Activity › Forums › Adobe Premiere Pro › CS6 BlackMagic Intensity Pro Playback on HD TV
Posted by Greg Burke on September 7, 2012 at 7:57 pmTrying to get playback on my HD TV through HDMI Out, But in CS6 they’re no BM Seq setting, I’m working in 720p at 30Fps, Cant find anything settings or get it working can anyone help me?
I wear many hats.
http://www.gregburkepost.comCraig Ricker replied 13 years, 10 months ago 4 Members · 8 Replies -
Greg Burke
September 7, 2012 at 10:24 pm -
Greg Burke
September 8, 2012 at 12:07 amCan you tell me where the BM options are located in CS6?
I wear many hats.
http://www.gregburkepost.com -
Walter Biscardi
September 8, 2012 at 12:20 pm[Greg Burke] “But in CS6 they’re no BM Seq setting, I’m working in 720p at 30Fps, Cant find anything settings or get it working can anyone help me?
“Settings for the individual video cards are gone with CS6. Through the Adobe Transmit Engine, the signal is automatically fed to your video card of choice if you have it selected in the Playback Preferences. So you just set up the Sequence for what you want to edit.
BlackMagic Cards can ONLY output “standard video signals” as we learned with our Decklink Extreme 3D card. 720p/30 or 720p/24 will NOT output directly from Premiere Pro via a BMD card.
If you want to see the footage, you have to create a 720p/60 (59.94) timeline and put your footage into that timeline and THEN you will see the footage output from the system.
With our AJA Kona boards and IoXT, they do a realtime conversion from 720p/30 to 720p/60 so we can see the video output to our external monitors even from the Source Window in Premiere Pro.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media“This American Land” – our new PBS Series.
Tero Ahlfors
September 8, 2012 at 7:17 pmOr put it into a 1080p30 sequence and copy the final cut to a 720p30 sequence when you’re ready to render.
Walter Biscardi
September 9, 2012 at 8:53 pm[Tero Ahlfors] “Or put it into a 1080p30 sequence and copy the final cut to a 720p30 sequence when you’re ready to render.”
That’s nice when you just have a little bit of footage. But in the case of the project I was working on, lots and lots of hours of 720p/30 material to review. Ended up moving the project to an AJA based system so we could see the material via the Source as well as the Program monitors.
Greg Burke
September 10, 2012 at 12:23 am -
Craig Ricker
November 27, 2012 at 1:31 amAre the preview files being displayed on the blackmagic card or is it some other feed to it? Like if I select I-Frame MPEG as my preview files, can I expect to have a lossy looking preview on the TV?
Secondly, by placing 720p25 footage into a 720p50 sequence am I seeing the same thing, or is there some conversion going on? Or does the Black magic card just treat the footage as interlaced which is fine as its progressive and thus both frames are the same?
