Activity Forums Avid Media Composer Creating targa lower 1/3 media
  • Creating targa lower 1/3 media
    Posted by Chris Bové on April 30, 2008 at 2:34 pm
    Desired outcome:
    Animated lower 1/3 in the form of a targa file with an alpha channel – for use in broadcast (non-editing) situation.
    Created in:
    MCA 2.8.1
    Question:
    What is the workflow? (I’ve never made a targa animation from an Avid before.)
    Thanks in advance!!!
    Chris Bové replied 18 years, 4 months ago 4 Members · 7 Replies
  • 7 Replies
  • Bouke Vahl
    April 30, 2008 at 2:41 pm
    Forget it. You need an alpha, and avid cannot output that.
    Use AE, everything is in the box…
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
  • Chris Bové
    April 30, 2008 at 8:01 pm
    Will do. Thanks!
  • Dylan Reeve
    May 1, 2008 at 10:57 am
    It can be done, but you’ll need to jump through hoops. It’s not really what Avid’s designed for. I second the AE suggestion, definitely the easier way.
  • Chris Bové
    May 2, 2008 at 3:13 pm
    Dylan – I love learning processes. Even though I’ll be doing this particular task in AE, what is the hoop-jumping process to do it in the Avid?
    ______
    /-o-o-
    `(=)`/…Pixel Monkey
    `(___)
    A picture says 1000 words. Editors give them meaning.
  • Michael Hancock
    May 2, 2008 at 3:50 pm
    Here’s how I’d do it…
    Because Avid can’t export a file with an alpha channel, you’ll need to export the matte and fill seperately. You have the lower third in Avid–export it as a Fill targa sequence just as you want it to look on air. Then select the matte key of your lower third and set it to Show Alpha so you get a black and white matte. Export that as a targa sequence.
    You’ll now need to either take both into After Effects or another compositing program to set the Fill targe sequence to use the Matte targe sequence as a luma matte, likely inverted, and rerender it as a Master targa sequence with alpha. Or, if you have the hardware to do it, use the Matte targa sequence as a luma matte to key out the lowerthird as it goes on air.
    Again, much, much easier to do it in AE.
    That’s how I’d do it!
    Michael.
  • Dylan Reeve
    May 3, 2008 at 3:01 am
    Pretty much what Michael said.
    There are some potential issues with a precomposed fill channel in doing it that way. It certainly can be done and I have used the method to export a Avid-built baseline key to be usable in a linear edit suite (although in that case I actually played them out to tape as a fill and matte signal).
  • Chris Bové
    May 8, 2008 at 6:58 pm
    Sweeeeeeeet.
    ______
    /-o-o-
    `(=)`/…Pixel Monkey
    `(___)
