Activity Forums Adobe After Effects Creating shapechanging mask from an alpha channel
  • Creating shapechanging mask from an alpha channel
    Posted by Joakim Dalfors on November 4, 2006 at 11:53 pm
    Hi!
    I am using RE vision Morph in AE to create a morph between several still frames. RE vision Morph uses masks to define how the morph is done. I have a couple of stills with a person cut out an placed on a transparent background and then precomposed so the alpha channel of the precomp contains the borders of the stills which I want to convert to masks. I know there is a feature called auto trace which will give me a mask for the outline. The problem is that it creates “hold keyframes” at every frame and since the stills arent moving, there is no interpolation between the masks. I tried making a new mask keyframe just every second (thats the spacing between my stills)using timeremapping but since the keyframes were “hold keyframes” it was still no interpolation. I tried to change them to “normal keyframes” but i guess the vertices where strangly distributed because there was interpolation now but the person on the stills was messed up (cut here and ther by the mask).
    So the question is: Is there a way to quickly make a mask from an alpha channel at time 0 and another at time 1 s and another at time 2 s and so on and combine them to one single mask whose shape is interpolated between the different samplings in time.
    thanks
    jodal
    Mylenium replied 19 years, 10 months ago 3 Members · 3 Replies
  • Jim Dodson
    November 5, 2006 at 1:05 am
    Have you tried “Autotrace”
    Layer–> Autotrace
    Should do what you need it to…
    Jim Dodson
    Quad 2.5 gig Mac – OSX
  • Jim Dodson
    November 5, 2006 at 3:04 am
    Ooops — sorry Jodal. Just re-read your post. You have tried Autotrace…
    Jim Dodson
  • Mylenium
    November 5, 2006 at 9:58 am
    No, not really. Masks have no way of relating to each other, so they never know where which vertex is or even how many of them form a contiguous shape. I’m afraid you’ll have to take the bitter pill and match them manually. If you findsome nice guy like Dan, they may be able to create a script for you that takes away some of the pain, but even then you’ll still have to do some manual cleanup.
    Mylenium
    [Pour Myl
