Activity Forums VEGAS Pro Creating Chapters in Vegas that will work on Mac
  • Creating Chapters in Vegas that will work on Mac
    Posted by Chuck Oldright on June 16, 2011 at 2:14 am
    Hello,
    I am a long time sony vegas video editor. I love it. I’m having a problem that I can not solve. I want to use sony vegas video for editing and iDVD for DVD authoring. Right now the only way I can do that is by rendering HDV video to M2T. Then converting it to h264 with mpeg streamclip. Then taking that file and bringing it into Final Cut Pro where I can insert chapters and render AGAIN. Is there any way to render the chapters in Vegas? The chapters won’t work.
    What am I missing here?!? If I can’t do it in Vegas is there a converter that will let me insert chapter markers so I don’t have to use FCP?
    Chuck
    John Rofrano replied 15 years, 1 month ago 2 Members · 1 Reply
  • John Rofrano
    June 17, 2011 at 6:03 pm
    [Chuck Oldright] “I want to use sony vegas video for editing and iDVD for DVD authoring. Right now the only way I can do that is by rendering HDV video to M2T. Then converting it to h264 with mpeg streamclip. Then taking that file and bringing it into Final Cut Pro where I can insert chapters and render AGAIN.”
    All DVD’s require MPEG2 video. You should be rendering an MPEG2 file from Vegas and not use MPEG Slipstream or iDVD to re-render two more times. You will get much higher quality this way and save two renders.
    [Chuck Oldright] “Is there any way to render the chapters in Vegas? The chapters won’t work.”
    Only if you use DVD Architect. Vegas makes chapter files for DVD Architect. I assume FCP makes chapter files for iDVD. See what chapter formats iDVD can import and then go to the Vegas Script Menu and see if it has a script that will export that format. Otherwise it’s best to use tools from a single vendor so that they can import to each others formats.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
