Activity Forums Apple Final Cut Pro Legacy Converting ProRes QT files to DV
  • Converting ProRes QT files to DV
    Posted by Erik Naso on April 1, 2008 at 2:22 am
    I have captured about 4 hours of HDV footage as ProRes and would like to convert some of the quicktime files to DV for another editor to edit on a premier pro NLE. Is this possible?
    Thanks for any help
    Erik
    Ivan George replied 16 years, 6 months ago 5 Members · 13 Replies
  • 13 Replies
  • Rafael Amador
    April 1, 2008 at 2:38 am
    Just put the clips in a DV sequence and export.
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Erik Naso
    April 1, 2008 at 3:24 am
    I tried a batch export and that seems to work. My settings are DV stream 16×9. I would put in a DV sequence and export but then that would be one big clip. I wanted to get smaller clips so they can bring them in to edit
  • Jeremy Garchow
    April 1, 2008 at 3:46 am
    Run all the clips individually through compressor.
    Premiere on PC or mac?
  • Erik Naso
    April 1, 2008 at 3:55 am
    Thanks for the help. They use
    premiere on a PC. Will compressor do a batch of a bunch of clips so I can run it while I sleep?
  • Jeremy Garchow
    April 1, 2008 at 4:09 am
    Oh yeah it will.
    You should find out what format they want. Most likely avi and not quicktime dv.
    You also have to make sure the tc is going to hold up so you can match back. I know compressor passes the timecode with quicktime movies, just not sure about avi movies.
    Try one and see. if it works, do them all.
    Jeremy
  • Erik Naso
    April 1, 2008 at 4:39 am
    I looked it up and Adobe will import DV-AVI (AVI) and QuickTime (MOV). Any suggestions on settings? I looked under Quicktime/uncompressed. Not real sure about this.
  • Rafael Amador
    April 1, 2008 at 9:45 am
    Don’t export as DV stream (.DV) because that is the kind of files used by iMovie. I don’t know if Premier will be able even to open then, but even in FC needs to be rendered.
    I don’t work with PCs but I think the best option is what I sayd before. Just put then in a DV sequence (time-line I mean, not .DV) and export as .mov with the NTSC DVCpro?DV codec.
    You don’t need to care even about field order. FC will set the “shift-fields” filter.
    And to get smaller clips, just chop, chop, chop…
    JVC DTV-17″
  • Jeremy Garchow
    April 1, 2008 at 2:24 pm
    Make a new Quicktime Movie preset in compressor and change the video settings to dv/dvcpro Ntsc and the audio to 48k 16bit stereo.
    You should ask them FIRST if they want avi or qt.
    Jeremy
  • Erik Naso
    April 2, 2008 at 4:09 am
    Thank You!
    I made a new preset for in compressor. QT 16×9 and that worked pretty well. Im sending a test clip to them to see if they can import it. It was pretty quick in the conversion of a 30 sec. clip so I hope a batch of several wouldn’t take to long to do.
    Thanks all for the suggestions.
    Erik
  • Erik Naso
    April 7, 2008 at 5:48 pm
    After soing several conversions my results are not good. I get a lot of jaggies or wavy lines in the QT video. Any settings I should try?
