Activity Forums Apple Final Cut Pro Legacy Converting ProRes QT files to DV
  • Danni Lewis
    April 11, 2008 at 9:28 pm
    Are you able to keep the same frame rate 23.98 going to DV? Need to do the same thing, but need to keep it 23.98.
  • Jeremy Garchow
    April 11, 2008 at 10:33 pm
    Yessir. Keep everything 23.98 and FCP will add the pulldown on playout via firewire, or any good capture card will add pulldown as well.
    Jeremy
  • Ivan George
    March 22, 2010 at 4:54 pm
    Are you still getting jagged edges? You’re going from upper to lower fields and I’m getting some bad results…
Page 2 of 2
