Activity › Forums › Adobe After Effects › converting 23.976 to 1080/60i
Posted by George Alexopoulos on August 30, 2010 at 8:36 pmHello,
I have a client that has asked me to deliver uncompressed QuickTime at 1080/60i. The project is all stuff made in after effect; mainly camera moves on photographs. I have set everything up at 1920×1080 at 23.976 fps. I rendered everything at 29.976 using a 3;2 pulldown – they are telling me there is a slight stutter… Am I not doing this correctly? Isn’t 60i really mean 29.976 interlaced? Any thoughts on how I might re render all of this or do I need to go into all the projects and make the compositions 30fps?
thanks
YorgoGeorge Alexopoulos replied 16 years ago 2 Members · 7 Replies -
Walter Soyka
August 30, 2010 at 9:23 pm[Yorgo Alexopoulos] “have a client that has asked me to deliver uncompressed QuickTime at 1080/60i. The project is all stuff made in after effect; mainly camera moves on photographs. I have set everything up at 1920×1080 at 23.976 fps. I rendered everything at 29.976 using a 3;2 pulldown – they are telling me there is a slight stutter… “
Follow Dave’s advice to the letter if they are expecting to receive 24p with pulldown for their 60i.
However, if they were expecting to receive 60i, it may be that 24p frame rate that they’re not happy with, and pull-down will not make the lower temporal resolution of 24p go away.
To get real, native 60i versions (not 24p with pull-down), simply create new comps at 1920×1080 / 29.97 fps. Drop your 1920×1080 / 23.976 comp into the 29.97 comp.
Make sure that none of the comps have “Preserve frame rate when nested” checked in their advanced composition settings, and make sure you turn on field rendering for output.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
George Alexopoulos
August 30, 2010 at 9:29 pmDave,
Thanks for the response. I do have everything set up the way you said:
My comps are set up as follows:
1920×1080
23.976 fps
I am pre rendering an image sequence (PNG) at 23.976 then re-rendering the sequence with a 3;2 pulldown as follows (and I am also making sure that the sequence is interpreted at 23.976 in my project before the re-render):Render setting:
1920×1080
3;2 pulldown
wsswwwMy final is a 1920×1080 uncompressed QuickTime at 29.976fps
is this not a 1080/60i movie? I thought it was? and they are saying it is slightly stuttering…
George Alexopoulos
August 30, 2010 at 9:39 pmDave –
I rendered it Lower Field first… I bet that is the problem!! I’ll re-render upper and see if that solves. it thanks. Just a quick note… when I am asked for 1080/60i movies as long as I’m delivering 1920×1080 rendered upper field at 29.976 fps I am good to go?
Best,
Yorgo -
George Alexopoulos
August 30, 2010 at 9:43 pmThanks Walter…
I’ll try what you both suggest. So, is 1080/60i need to be 29.97 (exactly) or is 29.976 still appropriate for 1080/60i delivery?
also – if I do what you suggest would it not be cleaner to go into all the comps individually and reset them to 29.97fps and move the keyframes into place? I am afraid that by just dropping in 23.976 comps into a 29.97 comp might create issues with the movement of elements?
thanks
Yorgo -
Walter Soyka
August 30, 2010 at 10:53 pmThere are two frame rates we’re discussing. 23.976, and 29.97.
29.976 is NOT a standard frame rate.
There’s no need to manually adjust all your keyframes. The procedure I outlined above will allow After Effects to smoothly and automatically re-interpret your animation at 29.97 fps (provided that you have no video footage).
Walter Soyka
George Alexopoulos
August 30, 2010 at 11:40 pmYeah – I was never able to get final deliver specs outta them at the start so I just set everything up the way they had it in their offline edit (23.976) and figured I’d just 3;2 pulldown it if I needed to finish at 29.98… There is a better “film” look I get when I produce things at 23.976 or 24fps rather than starting out at 30fps
thanks for all your help today.
