Activity › Forums › Apple Final Cut Pro Legacy › Convert to .flv HELP!!!!!!!!!!
Posted by Stefan Latoure on June 30, 2009 at 2:30 pmHello everyone! I am really in a pinch! I am converting a 90 sec clip shot in FCP out to a .mov file using the H264 codec. Then converting it to a .flv file using Prism, but it comes out very, very, choppy instead of smooth. This is for a contest, so I need to get this right ASAP! Any help given will be greatly appreciated!!
Here is a link to the file when it is converted;https://www.viddler.com/explore/Bygshorty/videos/2/
Bygshorty
John Fishbackreplied 17 years, 2 months ago 7 Members · 9 Replies
John Fishback
June 30, 2009 at 3:11 pmI’m not familiar with Prism. I use Sorenson Squeeze to encode flvs. My suggestion is export a QT ref or self-contained mov and then use Compressor to make an h.264 file. In the Inspector, in the Frame Controls tab, turn on Frame Controls and select Best for all quality settings. Set your web frame size and datarate. A higher datarate produces a higher quality result. After the encode, simply change the .mov extension of the encoded file to .flv and you should be good to go.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
John Carrithers
June 30, 2009 at 3:14 pmI’ve used On2 Technologies Flix pro for a couple years with good results. It will integrate into compressor and QT pro.
Walter Biscardi
June 30, 2009 at 3:18 pmThe cleanest video will be taking your original FCP quicktime and making the flash directly.
We use both Telestream Episode Pro and Adobe’s Flash Encoder to do this, though mostly Episode Pro.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Stefan Latoure
June 30, 2009 at 3:49 pmInteresting. So what is the difference between using the H264 in FCP and using the one in Compression using the same settings?
Bygshorty
David Bogie
June 30, 2009 at 4:06 pmYou could try the newest trick, too. Just export as H.264 and change the extension on the file to .flv. Flash Player 9 and up will play the files. We love this. But our IT geeks freak out because the video is so clean, they think we’re using too much bandwidth.
bogiesan
John Fishback
June 30, 2009 at 5:06 pmCompressor will produce a higher quality result. FCP’s scaler is nowhere near as good as Compressor’s. This is why you switch on Frame Controls and select Best for the quality settings in Compressor.
John
John Sellman
June 30, 2009 at 6:59 pmI second that. Export h.264.mov and change .mov to .flv. I’ve been doing this for a while and it works.
John Fishback
June 30, 2009 at 9:24 pmflv is a codec. It’s not mpeg-4. Neither is it h.264. The latest Flash Player, however, plays both the flv codec AND the h.264 codec. That is why if you make an h.264 mov and change the .mov to .flv, it will play in Flash Player.
John
