Activity Forums Adobe After Effects Expressions Convert mask vertices to text…
  • Convert mask vertices to text…
    Posted by Barend Onneweer on June 21, 2012 at 6:41 pm
    As part of a script I’m creating I’d like the script to draw a path on a solid or a shapelayer. Do do this I need to specify the vertices. I can easily draw a square or an ellipse but anything beyond becomes a rather tedious task. So ideally I’d prepare my shape in illustrator, paste it into After Effects and then somehow get the vertex data in text from the path…
    Is such a thing possible? Or should I just stick to a circle…
    Barend
    Raamw3rk – independent colourist and visual effects artist
    Barend Onneweer replied 14 years, 1 month ago 2 Members · 5 Replies
  • Barend Onneweer
    June 21, 2012 at 6:52 pm
    Hmmm… I can of course paste the path into the position property to get an array of coordinates… but when I paste the position keyframes into a text file there’s no tangent information.
  • Dan Ebberts
    June 21, 2012 at 7:23 pm
    That should work. Your script should be able to harvest the tangent arrays.
    Dan
  • Barend Onneweer
    June 24, 2012 at 7:39 pm
    Hi Dan,
    So… a little later I actually ‘got my nerd on’ and managed to get the full vertex data including tangents to a text file.
    Now I’m stuck getting the script to draw the shape as a shape layer.
    I found examples for generic built-in Ellipses etc, but I can’t figure out where exactly to put my vertex data… This must be one of the least travelled areas of AE scripting…
    This is what I got for drawing a generic Ellipse:
    var myEllipseSize = [100,200];
    var myStrokeColor = [1,0,0];
    var myShapeLayer= thisComp.layers.addShape();
    var myShapeLayerContents = myShapeLayer.property("ADBE Root Vectors Group");
    var myShapeGroup = myShapeLayerContents.addProperty("ADBE Vector Group");
    myShapeGroup.name = "Circle";
    var myEllipse = focusShapeGroup.property("ADBE Vectors Group").addProperty("ADBE Vector Shape - Ellipse");
    myEllipse.property("ADBE Vector Ellipse Size").setValue(myEllipseSize);
    And I get that I need to take out the Ellipse bits, but I’m missing something somewhere…
    Any pointers would once again be much appreciated!
  • Dan Ebberts
    June 24, 2012 at 9:23 pm
    The shape stuff is pretty tricky. This should draw a squished oval:
    var myVertices = [[0,-150],[-30,0],[0,150],[30,0]];
    var myInTangents = [[145,0],[0,-60],[-145,0],[0,60]];
    var myOutTangents = [[-145,0],[0,60],[145,0],[0,-60]];
    var myComp = app.project.activeItem;
    var myShapeLayer = myComp.layers.addShape();
    var myShapeLayerContents = myShapeLayer.property(“ADBE Root Vectors Group”);
    var myShapeGroup = myShapeLayerContents.addProperty(“ADBE Vector Group”);
    var myShapeContents = myShapeGroup.addProperty(“ADBE Vectors Group”);
    var myPathGroup = myShapeContents.addProperty(“ADBE Vector Shape – Group”);
    var myPathObject = myPathGroup.property(“ADBE Vector Shape”);
    var myPath = myPathObject.value;
    myPath.vertices = myVertices;
    myPath.inTangents = myInTangents;
    myPath.outTangents = myOutTangents;
    myPath.closed = true;
    myPathObject.setValue(myPath)
    Good luck. 🙂
    Dan
  • Barend Onneweer
    June 25, 2012 at 6:43 am
