Activity › Forums › Apple OS X › Compressor will not work
Posted by Chrome on July 8, 2006 at 9:33 amAfter working through the suggestions on the Apple Support I’m still very frustrated, so I turn to you to see if anyone has any suggestions. System is dual 2.5 PowerMac G5/8Gb/Decklink Blackmagic HD/Various internal/External HDDs/30″ Cinema.
Using Final Cut Studio with Compressor was working fine until in this order I… 1. Installed Tiger (now updated to 10.4.7), 2. Installed a ‘mighty’ mouse, 3. Installed Shake, 4. Performed a software ‘Update’ (I still have not installed latest versions of iTunes, iPod Updator & J2SE 5.0 rel 4).
Now… Shake, FCP, DVDSP and everything else I have tried works fine, however Compressor will not open. Message given in report is “Exception: EXC_BAD_ACCESS (0x0001), Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000, Thread 0 Crashed:” I’m assuming they are the relevant bits.
So I first deleted the prefernce files as per instructions – no joy, same problem.
Then I uninstalled Compressor and Qmaster, then re-installed them as per apple support instructions. Rebooted machine – but still the same problem.Any ideas? I would like to thank you for taking the time to read this post and any suggestions would be greatly appreciated, as I have a job to do this week and this is going to cause me a lot of problems if I cannot get it solved.
Cheers,
Chrome
Chrome replied 20 years, 2 months ago 3 Members · 15 Replies -
Simon Carlson-thies
July 8, 2006 at 1:42 pmHmmm…. thats odd, I had the same problem, but re-installing compressor fixed it… are you using the latest version of compressor…?
I am surprised that re-installing didn’t fix it since what you are dealing with is an error where Compressor tried to write to a protected memory location, and OSX stopped it… hence the crash…
Do you have any previously set jobs left…?
Simon Carlson-Thies,
Digital Light Graphics And Animation -
Chrome
July 8, 2006 at 5:36 pmYes it’s Compressor 2 as supplied on the Final Cut Studio disks. I then did a software update before running it.
I don’t understand what you mean by… “Do you have any previously set jobs left…?” if you mean did I have any batched up and ready to process or anything, the answer is no (AFAIK). However the first time it crashed I was launching it from within FCP in order to export using compressor. I opend batch monitor to check, but it’s blank.—
Cheers,
Chrome
Simon Carlson-thies
July 8, 2006 at 8:09 pmDid you try not updating it, just install the version that came on the disc, and try launching the application out of the apps folder rather then through FCP…
Simon Carlson-Thies
Chrome
July 8, 2006 at 9:27 pmYes that is how I did it. I did not actually launch it from FCP since the first time it crashed, just in case. But I did update it.
Jason Boucher
July 8, 2006 at 11:36 pmI am having that exact same problem. I installed Shake yesterday and bam… compressor will not open. I’ve deleted Shake and reinstalled compressor, trashed preferences, restarted, nothing….
Help???
Simon Carlson-thies
July 9, 2006 at 2:20 pmI said don’t update it and try it again… I would also try unplugging your Blackmagic system… also could you post more of the crash log…
Chrome
July 9, 2006 at 6:09 pmDone as suggested re:update but still crashing. I have not removed blackmagic yet, do I need to take the card out?
Here is the complete log:
Date/Time: 2006-07-09 19:07:39.129 +0100
OS Version: 10.4.7 (Build 8J135)
Report Version: 4Command: Compressor
Path: /Applications/Compressor.app/Contents/MacOS/Compressor
Parent: WindowServer [66]Version: 2.0.1 (2.0.1)
Build Version: 7
Project Name: Compressor
Source Version: 1560000PID: 397
Thread: 0Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000Thread 0 Crashed:
0 …apple.compressor.Compressor 0x0001147c 0x1000 + 66684
1 …apple.compressor.Compressor 0x00010a54 0x1000 + 64084
2 …apple.compressor.Compressor 0x0001f134 0x1000 + 123188
3 com.apple.AppKit 0x936e2ab0 -[NSIBObjectData nibInstantiateWithOwner:topLevelObjects:] + 928
4 com.apple.AppKit 0x936cec9c loadNib + 240
5 com.apple.AppKit 0x936ce6f4 +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 716
6 com.apple.AppKit 0x93725bc4 +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 156
7 com.apple.AppKit 0x937b5a70 +[NSBundle(NSNibLoading) loadNibNamed:owner:] + 344
8 …apple.compressor.Compressor 0x0001f7ac 0x1000 + 124844
9 …apple.compressor.Compressor 0x0001ffb8 0x1000 + 126904
10 …apple.compressor.Compressor 0x00044d64 0x1000 + 277860
11 …apple.compressor.Compressor 0x000438c0 0x1000 + 272576
12 …apple.compressor.Compressor 0x0003eae8 0x1000 + 252648
13 com.apple.AppKit 0x936e2ab0 -[NSIBObjectData nibInstantiateWithOwner:topLevelObjects:] + 928
14 com.apple.AppKit 0x936cec9c loadNib + 240
15 com.apple.AppKit 0x936ce6f4 +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 716
16 com.apple.AppKit 0x93725bc4 +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 156
17 com.apple.AppKit 0x937b5a70 +[NSBundle(NSNibLoading) loadNibNamed:owner:] + 344
18 …apple.compressor.Compressor 0x00042f4c 0x1000 + 270156
19 …apple.compressor.Compressor 0x00042ecc 0x1000 + 270028
20 …apple.compressor.Compressor 0x0001cd88 0x1000 + 114056
21 com.apple.Foundation 0x9294a668 -[NSSet makeObjectsPerformSelector:] + 164
22 com.apple.AppKit 0x936e2a70 -[NSIBObjectData nibInstantiateWithOwner:topLevelObjects:] + 864
23 com.apple.AppKit 0x936cec9c loadNib + 240
24 com.apple.AppKit 0x936ce6f4 +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 716
25 com.apple.AppKit 0x93725bc4 +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 156
26 com.apple.AppKit 0x937b5a70 +[NSBundle(NSNibLoading) loadNibNamed:owner:] + 344
27 com.apple.prokit 0x9625a4e8 NSProApplicationMain + 244
28 …apple.compressor.Compressor 0x0000f218 0x1000 + 57880
29 …apple.compressor.Compressor 0x0000e5d8 0x1000 + 54744
30 dyld 0x8fe01048 _dyld_start + 60Thread 1:
0 libSystem.B.dylib 0x9002c2e8 semaphore_wait_signal_trap + 8
1 libSystem.B.dylib 0x90030dcc pthread_cond_wait + 480
2 com.apple.ColorSync 0x91597224 pthreadSemaphoreWait(t_pthreadSemaphore*) + 56
3 com.apple.ColorSync 0x915964c0 CMMConvTask(void*) + 40
4 libSystem.B.dylib 0x9002bc28 _pthread_body + 96Thread 0 crashed with PPC Thread State 64:
srr0: 0x000000000001147c srr1: 0x100000000200f030 vrsave: 0x0000000000000000
cr: 0x22000402 xer: 0x0000000000000000 lr: 0x000000000001147c ctr: 0x0000000094ace5b8
r0: 0x000000000001147c r1: 0x00000000bfffebc0 r2: 0x00000000a4a8c518 r3: 0x0000000000000000
r4: 0x0000000000000000 r5: 0x0000000000000000 r6: 0x00000000000e4b90 r7: 0x00000000016dbf40
r8: 0x00000000000e4b6c r9: 0x00000000016dbf40 r10: 0x00000000bfffeb80 r11: 0x0000000000000000
r12: 0x0000000094ace5b8 r13: 0x0000000000306db0 r14: 0x00000000000e740c r15: 0x00000000000e72e0
r16: 0x0000000000000008 r17: 0x00000000a36fe428 r18: 0x00000000000e71c4 r19: 0x00000000a36fe428
r20: 0x00000000000e7218 r21: 0x00000000000e71c8 r22: 0x00000000a3702710 r23: 0x00000000000e8528
r24: 0x00000000000e0000 r25: 0x00000000016cdad0 r26: 0x000000000000000a r27: 0x00000000016dbe20
r28: 0x00000000000e7854 r29: 0x0000000000000000 r30: 0x0000000000000031 r31: 0x00000000936e2710Binary Images Description:
0x1000 – 0xd4fff com.apple.compressor.Compressor 2.0.1 /Applications/Compressor.app/Contents/MacOS/Compressor
0x2a5000 – 0x2c2fff com.apple.prokit.TigerPanels 3.1 (589) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/Resources/TigerPanels.bundle/Contents/MacOS/TigerPanels
0x1572000 – 0x157dfff com.apple.LiveType.component 2.0.2 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x158b000 – 0x1590fff com.apple.motion.component 1.0 /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x7dbb0000 – 0x7dbb9fff Motion /Library/Frameworks/Motion.framework/Versions/A/Motion
0x7ffd0000 – 0x7ffd8fff com.apple.AEProfiling 1.2 (13) /Applications/Compressor.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
0x7fff0000 – 0x80004fff com.apple.AERegistration 1.2 (51) /Applications/Compressor.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
0x80040000 – 0x80041fff com.apple.Helium 2.0.3 /System/Library/PrivateFrameworks/Helium.framework/Versions/A/Helium
0x8668e000 – 0x866f6fff com.apple.LiveType.framework 2.0.2 /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
0x8fe00000 – 0x8fe52fff dyld 45.1 /usr/lib/dyld
0x90000000 – 0x901bbfff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x90213000 – 0x90218fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x9021a000 – 0x90267fff com.apple.CoreText 1.0.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90292000 – 0x90343fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90652000 – 0x906eafff com.apple.AECore 2.0 (2.1) /Library/Frameworks/AECore.framework/Versions/A/AECore
0x9074f000 – 0x9075efff com.apple.qmaster.ClusterManager 2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
0x907b9000 – 0x90892fff com.apple.CoreFoundation 6.4.6 (368.27) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x908db000 – 0x908dbfff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x909b2000 – 0x909bafff com.apple.qmaster.RequestProcessing 2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
0x909ca000 – 0x909d7fff com.apple.qmaster.ServiceControl 2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
0x909eb000 – 0x909f9fff com.apple.qmaster.Status 2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
0x90a12000 – 0x90a42fff com.apple.qmaster.SwampCore 2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
0x90a6e000 – 0x90a79fff com.apple.qmaster.SwampExecutor 2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
0x90a89000 – 0x90a93fff com.apple.qmaster.SwampService 2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
0x90ae7000 – 0x90b57fff IOKit /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90b6d000 – 0x90b7ffff libauto.dylib /usr/lib/libauto.dylib
0x90ba2000 – 0x90c0afff com.apple.compressor.StompTypes 2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
0x90c47000 – 0x90c52fff com.apple.compressor.MediaServerAPI 2.1 /Library/Frameworks/MediaServerAPI.framework/Versions/A/MediaServerAPI
0x90ec3000 – 0x90f43fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f8d000 – 0x90fcefff com.apple.CFNetwork 129.16 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90fe3000 – 0x90ffbfff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x9100b000 – 0x9108cfff com.apple.SearchKit 1.0.5 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x910d2000 – 0x910fbfff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9110c000 – 0x9111afff libz.1.dylib /usr/lib/libz.1.dylib
0x9111d000 – 0x912d7fff com.apple.security 4.4 (27566) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913d5000 – 0x913defff com.apple.DiskArbitration 2.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x913e5000 – 0x9140dfff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91420000 – 0x9142bfff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x91430000 – 0x91438fff libbsm.dylib /usr/lib/libbsm.dylib
0x9143c000 – 0x914b7fff com.apple.audio.CoreAudio 3.0.4 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x914f4000 – 0x914f4fff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x914f6000 – 0x9152efff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91549000 – 0x91616fff com.apple.ColorSync 4.4.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9166b000 – 0x916fcfff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x91743000 – 0x917fafff com.apple.QD 3.10.20 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91837000 – 0x91895fff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x918c4000 – 0x918e5fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x918f9000 – 0x9191efff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x91931000 – 0x91973fff com.apple.LaunchServices 180 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9198f000 – 0x919a3fff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x919b1000 – 0x919f1fff com.apple.ImageIO.framework 1.4.7 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91a07000 – 0x91acffff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91b1d000 – 0x91b32fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91b37000 – 0x91b54fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91b59000 – 0x91bc8fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91bdf000 – 0x91be3fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91be5000 – 0x91c2dfff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91c32000 – 0x91c6ffff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91c76000 – 0x91c8ffff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91c94000 – 0x91c97fff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91c99000 – 0x91c99fff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91c9b000 – 0x91d80fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91d88000 – 0x91da7fff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91e13000 – 0x91e81fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91e8c000 – 0x91f21fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91f3b000 – 0x924c3fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x924f6000 – 0x92821fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92851000 – 0x928d9fff com.apple.DesktopServices 1.3.4 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9291a000 – 0x92b45fff com.apple.Foundation 6.4.6 (567.27) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92c63000 – 0x92d41fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x92d61000 – 0x92e4ffff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92e61000 – 0x92e7ffff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92e8a000 – 0x92ee4fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92f02000 – 0x92f02fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92f04000 – 0x92f18fff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92f30000 – 0x92f40fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92f4c000 – 0x92f61fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92f73000 – 0x92ffafff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x9300e000 – 0x93019fff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x93023000 – 0x93050fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9306a000 – 0x93079fff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x93085000 – 0x930ebfff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x9311c000 – 0x9316bfff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x93199000 – 0x931b6fff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x931c8000 – 0x931d5fff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x931de000 – 0x934ebfff com.apple.HIToolbox 1.4.8 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x9363a000 – 0x93646fff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9364b000 – 0x9366bfff com.apple.DirectoryService.Framework 3.1 /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x936be000 – 0x936befff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x936c0000 – 0x93cf3fff com.apple.AppKit 6.4.7 (824.41) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x94080000 – 0x940f0fff com.apple.CoreData 80 /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x94129000 – 0x941ecfff com.apple.audio.toolbox.AudioToolbox 1.4.3 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9423e000 – 0x9423efff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x94240000 – 0x943f3fff com.apple.QuartzCore 1.4.8 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94446000 – 0x94483fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x9448b000 – 0x944dbfff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x9451b000 – 0x9455ffff com.apple.bom 8.4 (86.2) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x9456b000 – 0x945a3fff com.apple.vmutils 4.0.0 (85) /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
0x9467e000 – 0x9468dfff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x94695000 – 0x946a2fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x946e8000 – 0x94701fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x94708000 – 0x949bcfff com.apple.QuickTime 7.1.2 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94a80000 – 0x94af1fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x94b64000 – 0x94b85fff libmx.A.dylib /usr/lib/libmx.A.dylib
0x94c8d000 – 0x94dbdfff com.apple.AddressBook.framework 4.0.4 (485.1) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x94e4f000 – 0x94e5efff com.apple.DSObjCWrappers.Framework 1.1 /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x94e66000 – 0x94e93fff com.apple.LDAPFramework 1.4.1 (69.0.1) /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x94e9a000 – 0x94eaafff libsasl2.2.dylib /usr/lib/libsasl2.2.dylib
0x94eae000 – 0x94eddfff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib
0x94eed000 – 0x94f0afff libresolv.9.dylib /usr/lib/libresolv.9.dylib
0x9623a000 – 0x9630cfff com.apple.prokit 3.1 (589) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
0x96ec2000 – 0x96ee1fff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9968d000 – 0x9975dfff com.apple.QuickTime3GPP.component 7.1.2 /System/Library/QuickTime/QuickTime3GPP.component/Contents/MacOS/QuickTime3GPP
0x9f1a2000 – 0x9f1bdfff com.apple.qmaster.SwampUI 2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
0x9f1d2000 – 0x9f27cfff com.apple.qmaster.JobControl 2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
0x9f30c000 – 0x9f340fff com.apple.qmaster.ContentControl 2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
0x9f369000 – 0x9f3bbfff com.apple.qmaster.do 2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
0x9f40e000 – 0x9f43bfff com.apple.qmaster.SwampTypes 2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
0x9f46a000 – 0x9f476fff com.apple.qmaster.SwampUtil 2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
0x9f482000 – 0x9f4b3fff com.apple.compressor.StompUI 2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
0x9f4cc000 – 0x9f5a2fff com.apple.compressor.transcoding 2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
0x9f607000 – 0x9f60dfff com.apple.compressor.FilterUI 2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
0x9f612000 – 0x9f61bfff com.apple.compressor.StompUtil 2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
0x9f624000 – 0x9f64ffff com.apple.compressor.ImageProcessing 2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
0x9f66e000 – 0x9f945fff com.apple.CoreServices.CarbonCore 681.4 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9f9ab000 – 0x9fa2ffff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x9fa59000 – 0x9fe13fff com.apple.CoreGraphics 1.258.33 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9fea0000 – 0x9ffa2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x9fffc000 – 0x9fffcfff com.apple.qmaster.swamp 2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
0x9fffe000 – 0x9fffefff com.apple.compressor.stomp 2.1 /Library/Frameworks/Compressor.framework/Versions/A/CompressorModel: PowerMac7,3, BootROM 5.1.8f7, 2 processors, PowerPC G5 (3.0), 2.5 GHz, 8 GB
Graphics: NVIDIA GeForce 6800 Ultra DDL, GeForce 6800 Ultra, AGP, 256 MB
Memory Module: DIMM0/J11, 1 GB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM1/J12, 1 GB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM2/J13, 1 GB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM3/J14, 1 GB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM4/J41, 1 GB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM5/J42, 1 GB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM6/J43, 1 GB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM7/J44, 1 GB, DDR SDRAM, PC3200U-30330
Modem: Jump, , V.92, Version 1.0,
Network Service: Built-in Ethernet, Ethernet, en0
PCI Card: pci10b5,a100, sppci_video, SLOT-3
PCI Card: firewire, ieee1394, SLOT-4
Serial ATA Device: Maxtor 6Y160M0, 152.67 GB
Parallel ATA Device: HL-DT-ST DVD-RW GWA-4082B, 1.01 GB
USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
USB Device: Apple Optical USB Mouse, Mitsumi Electric, Up to 1.5 Mb/sec, 100 mA
USB Device: ProtectExecuter, Syncrosoft, Up to 12 Mb/sec, 100 mA
USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
USB Device: Hub, , Up to 480 Mb/sec, 500 mA
USB Device: ShuttlePRO v2, Contour Design, Up to 1.5 Mb/sec, 500 mA
USB Device: Apple Cinema HD Display, , Up to 1.5 Mb/sec, 500 mA
FireWire Device: unknown_device, unknown_value, Up to 400 Mb/sec
FireWire Device: OXFORD IDE Device 1, Medea G-RAID, Up to 800 Mb/sec
FireWire Device: 1394 Storage Front Panel*, Maxtor, Up to 400 Mb/sec
FireWire Device: 911Plus Drive, Oxford, Up to 800 Mb/sec
FireWire Device: 1394 Storage Front Panel*, Maxtor, Up to 800 Mb/sec
FireWire Device: unknown_device, unknown_value, Unknown—
Cheers,
Chrome
Simon Carlson-thies
July 9, 2006 at 7:21 pmWell I was hoping to see a underlying component problem but it appears to be contained in compressor… As to the blackmagic thing try both unplugging any cables and also try removing the card… Did you verify permissions when you updated your software?
I would go ahead and install the rest of the updates since I don’t think those are part of the problem…
When you re-installed did you get rid of all the compressor reciepts… and are you sure you got all elements of the program? Application Support Files…
If none of that works there is always re-install final cut studio… but to be honest I am not sure why you’re still having the problem, since when I had the same problem re-installing fixed it…
Simon Carlson-thies
July 10, 2006 at 5:42 pmThere is one other possibility that occurs to me, you may want to try deleting your cache folder of Compressor which is in your user library folder in the Cache folder… Don’t delete the cache folder just compressors sub folder.
You may also want to consider a re-install of your OSX update… which I assume you are aware of how to easily do that…
Simon Carlson-Thies
Jason Boucher
July 10, 2006 at 9:14 pmI am experiencing the same problem. On the Final Cut Pro forum a member offered some advice, but that didn’t seem to work either. I’m wondering if there is a way to restore my system back to last week before this problem occured. I know could do it on a PC but I think I used 3rd party software. Any other thougts? Error report, which I cannot read for the life of me, is attached.
Thank again!
JasonDate/Time: 2006-07-10 16:53:57.466 -0400
Parent: WindowServer [57]Version: 2.0 (2.0)
Build Version: 2
Source Version: 1440000PID: 340
0 …apple.compressor.Compressor 0x000113f4 0x1000 + 66548
1 …apple.compressor.Compressor 0x00010a24 0x1000 + 64036
2 …apple.compressor.Compressor 0x0001f020 0x1000 + 122912
3 com.apple.AppKit 0x936e7ab0 -[NSIBObjectData nibInstantiateWithOwner:topLevelObjects:] + 928
4 com.apple.AppKit 0x936d3c9c loadNib + 240
5 com.apple.AppKit 0x936d36f4 +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 716
6 com.apple.AppKit 0x9372abc4 +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 156
7 com.apple.AppKit 0x937baa70 +[NSBundle(NSNibLoading) loadNibNamed:owner:] + 344
8 …apple.compressor.Compressor 0x0001f698 0x1000 + 124568
9 …apple.compressor.Compressor 0x0001fea4 0x1000 + 126628
10 …apple.compressor.Compressor 0x00044ab0 0x1000 + 277168
11 …apple.compressor.Compressor 0x00043614 0x1000 + 271892
12 …apple.compressor.Compressor 0x0003e83c 0x1000 + 251964
13 com.apple.AppKit 0x936e7ab0 -[NSIBObjectData nibInstantiateWithOwner:topLevelObjects:] + 928
14 com.apple.AppKit 0x936d3c9c loadNib + 240
15 com.apple.AppKit 0x936d36f4 +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 716
16 com.apple.AppKit 0x9372abc4 +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 156
17 com.apple.AppKit 0x937baa70 +[NSBundle(NSNibLoading) loadNibNamed:owner:] + 344
18 …apple.compressor.Compressor 0x00042ca0 0x1000 + 269472
19 …apple.compressor.Compressor 0x00042c20 0x1000 + 269344
20 …apple.compressor.Compressor 0x0001cd00 0x1000 + 113920
21 com.apple.Foundation 0x9294e668 -[NSSet makeObjectsPerformSelector:] + 164
22 com.apple.AppKit 0x936e7a70 -[NSIBObjectData nibInstantiateWithOwner:topLevelObjects:] + 864
23 com.apple.AppKit 0x936d3c9c loadNib + 240
24 com.apple.AppKit 0x936d36f4 +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 716
25 com.apple.AppKit 0x9372abc4 +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 156
26 com.apple.AppKit 0x937baa70 +[NSBundle(NSNibLoading) loadNibNamed:owner:] + 344
27 com.apple.prokit 0x9625d4e8 NSProApplicationMain + 244
2 com.apple.ColorSync 0x91598224 pthreadSemaphoreWait(t_pthreadSemaphore*) + 56
3 com.apple.ColorSync 0x915974c0 CMMConvTask(void*) + 40
srr0: 0x00000000000113f4 srr1: 0x100000000200f030 vrsave: 0x0000000000000000
cr: 0x22000402 xer: 0x0000000000000000 lr: 0x00000000000113f4 ctr: 0x0000000094ad15b8
r0: 0x00000000000113f4 r1: 0x00000000bfffeba0 r2: 0x00000000a4a8f518 r3: 0x0000000000000000
r4: 0x0000000000000000 r5: 0x0000000000000000 r6: 0x00000000000e3b10 r7: 0x000000001672acd0
r8: 0x00000000000e3aec r9: 0x000000001672acd0 r10: 0x00000000bfffeb60 r11: 0x0000000000000000
r12: 0x0000000094ad15b8 r13: 0x0000000000306f80 r14: 0x00000000000e640c r15: 0x00000000000e62e0
r16: 0x0000000000000008 r17: 0x00000000a3703428 r18: 0x00000000000e61c4 r19: 0x00000000a3703428
r20: 0x00000000000e6218 r21: 0x00000000000e61c8 r22: 0x00000000a3707710 r23: 0x00000000000e7520
r24: 0x00000000000e0000 r25: 0x000000001671ca80 r26: 0x000000000000000a r27: 0x00000000167295a0
r28: 0x00000000000e6850 r29: 0x0000000000000000 r30: 0x0000000000000031 r31: 0x00000000936e7710Binary Images Description:
0x1000 – 0xd3fff com.apple.compressor.Compressor 2.0 /Applications/Compressor.app/Contents/MacOS/Compressor
0x2a2000 – 0x2bffff com.apple.prokit.TigerPanels 3.1 (589) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/Resources/TigerPanels.bundle/Contents/MacOS/TigerPanels
0x610000 – 0x61bfff com.apple.LiveType.component 2.0.2 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x629000 – 0x62efff com.apple.motion.component 1.0 /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x75a000 – 0x7affff com.DivXInc.DivXDecoder 6.0.0 /Library/QuickTime/DivX 6 Decoder.component/Contents/MacOS/DivX 6 Decoder
0x7f950000 – 0x7f9b8fff com.apple.LiveType.framework 2.0.2 /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
0x90ae7000 – 0x90b57fff com.apple.framework.IOKit 1.4.1 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x910d2000 – 0x910fcfff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9110d000 – 0x9111bfff libz.1.dylib /usr/lib/libz.1.dylib
0x9111e000 – 0x912d8fff com.apple.security 4.4 (27566) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913d6000 – 0x913dffff com.apple.DiskArbitration 2.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x913e6000 – 0x9140efff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91421000 – 0x9142cfff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x91431000 – 0x91439fff libbsm.dylib /usr/lib/libbsm.dylib
0x9143d000 – 0x914b8fff com.apple.audio.CoreAudio 3.0.4 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x914f5000 – 0x914f5fff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x914f7000 – 0x9152ffff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9154a000 – 0x91617fff com.apple.ColorSync 4.4.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9166c000 – 0x916fdfff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x91744000 – 0x917fbfff com.apple.QD 3.10.20 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91838000 – 0x91896fff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x918c5000 – 0x918e9fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x918fd000 – 0x91922fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x91935000 – 0x91977fff com.apple.LaunchServices 180 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x91993000 – 0x919a7fff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x919b5000 – 0x919f5fff com.apple.ImageIO.framework 1.4.7 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91a0b000 – 0x91ad3fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91b21000 – 0x91b36fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91b3b000 – 0x91b58fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91b5d000 – 0x91bccfff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91be3000 – 0x91be7fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91be9000 – 0x91c31fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91c36000 – 0x91c73fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91c7a000 – 0x91c93fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91c98000 – 0x91c9bfff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91c9d000 – 0x91c9dfff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91c9f000 – 0x91d84fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91d8c000 – 0x91dabfff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91e17000 – 0x91e85fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91e90000 – 0x91f25fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91f3f000 – 0x924c7fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x924fa000 – 0x92825fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92855000 – 0x928ddfff com.apple.DesktopServices 1.3.4 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9291e000 – 0x92b49fff com.apple.Foundation 6.4.6 (567.27) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92c67000 – 0x92d45fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x92d65000 – 0x92e53fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92e65000 – 0x92e83fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92e8e000 – 0x92ee8fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92f06000 – 0x92f06fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92f08000 – 0x92f1cfff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92f34000 – 0x92f44fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92f50000 – 0x92f65fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92f77000 – 0x92ffefff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x93012000 – 0x9301dfff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x93027000 – 0x93054fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9306e000 – 0x9307efff com.apple.print.framework.Print 5.0 (190.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9308a000 – 0x930f0fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x93121000 – 0x93170fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9319e000 – 0x931bbfff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x931cd000 – 0x931dafff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x931e3000 – 0x934f0fff com.apple.HIToolbox 1.4.8 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x9363f000 – 0x9364bfff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x93650000 – 0x93670fff com.apple.DirectoryService.Framework 3.1 /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x936c3000 – 0x936c3fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x936c5000 – 0x93cf8fff com.apple.AppKit 6.4.7 (824.41) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x94085000 – 0x940f5fff com.apple.CoreData 80 /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9412e000 – 0x941f1fff com.apple.audio.toolbox.AudioToolbox 1.4.3 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x94243000 – 0x94243fff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x94245000 – 0x943f8fff com.apple.QuartzCore 1.4.8 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9444b000 – 0x94488fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x94490000 – 0x944e0fff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x94520000 – 0x94564fff com.apple.bom 8.4 (86.2) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x94570000 – 0x945a8fff com.apple.vmutils 4.0.0 (85) /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
0x94683000 – 0x94692fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x9469a000 – 0x946a6fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x946ec000 – 0x94704fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x9470b000 – 0x949bffff com.apple.QuickTime 7.1.2 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94a83000 – 0x94af4fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x94b67000 – 0x94b88fff libmx.A.dylib /usr/lib/libmx.A.dylib
0x94c90000 – 0x94dc0fff com.apple.AddressBook.framework 4.0.4 (485.1) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x94e52000 – 0x94e61fff com.apple.DSObjCWrappers.Framework 1.1 /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x94e69000 – 0x94e96fff com.apple.LDAPFramework 1.4.1 (69.0.1) /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x94e9d000 – 0x94eadfff libsasl2.2.dylib /usr/lib/libsasl2.2.dylib
0x94eb1000 – 0x94ee0fff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib
0x94ef0000 – 0x94f0dfff libresolv.9.dylib /usr/lib/libresolv.9.dylib
0x9623d000 – 0x9630ffff com.apple.prokit 3.1 (589) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
0x96ec5000 – 0x96ee4fff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x976ea000 – 0x976f7fff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x98b91000 – 0x99567fff com.apple.QuickTimeComponents.component 7.1.2 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x9968f000 – 0x9975ffff com.apple.QuickTime3GPP.component 7.1.2 /System/Library/QuickTime/QuickTime3GPP.component/Contents/MacOS/QuickTime3GPP
0x9fffe000 – 0x9fffefff com.apple.compressor.stomp 2.1 /Library/Frameworks/Compressor.framework/Versions/A/CompressorModel: PowerMac11,2, BootROM 5.2.7f1, 2 processors, PowerPC G5 (1.1), 2.3 GHz, 3 GB
Graphics: NVIDIA GeForce 6600, GeForce 6600, PCI, 256 MB
Memory Module: DIMM0/J6700, 512 MB, DDR2 SDRAM ECC, PC2-4200E-444
Memory Module: DIMM1/J6800, 512 MB, DDR2 SDRAM ECC, PC2-4200E-444
Memory Module: DIMM2/J6900, 1 GB, DDR2 SDRAM ECC, PC2-4200E-444
Memory Module: DIMM3/J7000, 1 GB, DDR2 SDRAM ECC, PC2-4200E-444
Network Service: Built-in Ethernet 1, Ethernet, en0
PCI Card: GeForce 6600, Display, SLOT-1
PCI Card: bcom5714, network, GIGE
PCI Card: pci1095,3132, sppci_othermassstorage, SLOT-2
Serial ATA Device: WDC WD2500JS-41MVB1, 232.89 GB
Serial ATA Device: Maxtor 7Y250M0, 233.76 GB
Parallel ATA Device: HL-DT-ST DVD-RW GWA-4165B,
USB Device: iPod, Apple, Up to 480 Mb/sec, 500 mA
FireWire Device: IoLA, AJA Video Systems, Inc., Up to 400 Mb/sec
