Activity › Forums › Apple Final Cut Pro Legacy › Compressor questions
Posted by John Nelson on June 3, 2013 at 8:33 pmI bought a mac pro in January and migrated my software; fcp, etc. from my macbookpro.
The first time I tried to use compressor after the migration it gave ‘no read or right’ errors. I worked around by using quicktime. Today I tried again and received the same message so I checked my drives and found the system was the only one with read/right permissions. I changed the admin to this and tried again. Same errors on compressor.
I don’t know what else to try. Any suggestions?
Thanks.
Using version 3.05
John Nelson replied 13 years, 3 months ago 2 Members · 18 Replies -
Shane Ross
June 3, 2013 at 9:07 pmMigrating the Final Cut Studio apps won’t work. There are too many supporting files it installs throughout the system that Migrating doesn’t get. You need to install the apps from the original DVDs.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
John Nelson
June 4, 2013 at 12:18 amThanks. I have the discs and will do an new install. Hope I don’t loose anything in the process?
Shane Ross
June 4, 2013 at 12:45 amYou won’t lose anything. Make sure you run the system update too, to get fully current.
Shane
Little Frog Post
John Nelson
June 4, 2013 at 4:23 pmThanks again, Shane. Before I get started, my discs are an upgrade from previous. Since I haven’t done this in awhile, will that matter? Should I do a complete install with all the discs?
Thanks.
Shane Ross
June 4, 2013 at 5:20 pmJust have the original serial number handy. Install the upgrade, it will ask for that number/
Shane
Little Frog Post
John Nelson
June 4, 2013 at 7:46 pmShane, install won’t work due to FPS being version 6.06. Error says it no longer supports power pc’s, which I no longer have. Working with a mac pro, 8 core with 36gb of ram. Any way to work around this?
Thanks.
Shane Ross
June 4, 2013 at 8:04 pmYou are trying to install FCP 6…FCS2…onto a NEW computer, running MacOS 10.8, Mountain Lion…right?
FCP 7 (4 years old) isn’t supported on that OS (meaning Apple didn’t test it to make sure it works, and plug any bugs)…they certainly didn’t take into account the 6 year old FCS 2. The only way to install that onto your computer is to use Pacifist to hack things a bit.
https://discussions.apple.com/thread/5068243?tstart=30
Shane
Little Frog Post
John Nelson
June 4, 2013 at 8:09 pmBummer. It’s actually a refurb from mid-2010 running lion, not mountain lion. Don’t imagine I’ll find any hackers here, in the middle of the Caribbean. :{
Shane Ross
June 4, 2013 at 8:15 pmAh…Lion is a tad easier. If you have a Snow Leopard installer, install ROSETTA from that (do a Custome Install). Then the FCS2 installer will work fine.
Mountain Lion is the one that requires Pacifist.
Shane
Little Frog Post
