Activity › Forums › Apple Final Cut Pro Legacy › Compressor questions
  • John Nelson
    June 4, 2013 at 8:27 pm
    Great. So I dig out my Snow Leopard, look for rosetta installer, install it on the lion with a custom install, then install FCS2, right? Sorry. Getting older by the minute. :}
    https://www.omproductions.net
  • Shane Ross
    June 4, 2013 at 8:55 pm
    Yes…right
    Shane
    Little Frog Post
  • John Nelson
    June 4, 2013 at 9:29 pm
    Found it. Re installing. Thanks!
  • John Nelson
    June 5, 2013 at 12:32 am
    Done. Didn’t even ask for the SN’s. Thanks.
  • John Nelson
    June 5, 2013 at 1:29 am
    Did the install but compressor still doesn’t work. Same message about the read/wright error. Any thoughts?
  • Shane Ross
    June 5, 2013 at 2:15 am
    Compressor Repair…from digitalrebellion.com.
    Shane
    Little Frog Post
  • John Nelson
    June 9, 2013 at 6:56 pm
    Guess I’m trying to beat a dead horse on this but still can’t get it to work. Exporting project from fcp to compressor I get the ‘you don’t have permission to write to disk’ error. Exporting as quicktime the file has no extension (.mov) in the finder. But it does when I view the ‘save as’ box. I’m trying to make a DVD. So when I try to import the quicktime into DVDSP I get ‘not acceptable format’ error. Went to digital rebellion and downloaded their compressor repair. Still having problems. Did a complete re-install of FCS also. I sent a similar message to DR but am going nutz trying to figure this out. Thanks.
  • John Nelson
    June 11, 2013 at 5:18 pm
    Here’s an interesting question which may answer why compressor keeps coming up with ‘no read/write’ permissions. I checked my internal drive and discovered that the “admin” name on the drive has changed to “wheel”. Who, or why that happened remains a mystery. The question is, how can I change it back? I fear if I start messing with the + and – on the account information I may screw up the whole drive and lose access. Again, any suggestions? Thanks.
Page 2 of 2
