Activity › Forums › Apple Final Cut Pro Legacy › Compressor 3 – Hit Submit, Nothing Happens
Phil Goodwin replied 15 years, 5 months ago 10 Members · 32 Replies
Rosie Walunas
January 26, 2011 at 5:05 pmI am having similar issues, however, I cannot locate the “/var/spool/qmaster/” folder. It says the folder does not exists. I check in System Preferences and I am not able to edit the Cluster Storage location of “/var/spool/qmaster/”.
Help is much appreciated; thanks!
Phil Goodwin
April 20, 2011 at 10:23 pmThis worked great for me. Thanks!
My Compressor problem started when I noticed Compressor was stalled and “Startup Disk Full” appeared on my usually spacious hard drive. I discovered that compressor creates temporary files in the var/spool/qmaster filepath, and fills up your hard drive (my qmaster folder was 25GB). So I deleted everything in the qmaster folder. Dumb! Compressor was confused. But after your steps above, everything works great again. Thanks!
