Activity › Forums › Adobe After Effects › compound blur
  • compound blur
    Posted by Roger Burton on January 20, 2006 at 3:43 pm
    Hi I want to blur the left hand side of a shot so its blurred heavily on the left and towards the centre becomes sharp …. well I figured compound blur . I created a ramp layer graduated from blk to wht and thought I’d be able to pick that layer as the blurring map but I get an allover blur … I’ve tried applying CB to both layers … pre comping …. everything ….any help please … Have good weekends …Roger
    Roger Burton replied 20 years, 8 months ago 5 Members · 4 Replies
  • Barend Onneweer
    January 20, 2006 at 4:14 pm
    1. Drag your footage into a comp
    2. Create a new comp of the same size for the gradient.
    3. Create a new solid in this comp, and apply the Ramp effect.
    4. Drag this gradient comp into your new comp, below the footage layer and turn off visibility for the gradient comp.
    5. Apply Compound Blur to your footage layer, and set the Blur Layer to your gradient comp.
    Should work.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Chris Zwar
    January 20, 2006 at 4:35 pm
    Just as an aside, I find the quality of AE’s compound blur to be pretty poor when compared to 3rd party compound blurs. The Pinnacle one (which comes with Composite Wizard) gives a MUCH better result, and if there’s a Tinderbox, Boris or Saphire equivalent then I’m sure the difference will be just as noticable.
    -Chris
    Motion Graphics Designer
    Will animate for food
  • Peter Litwinowicz
    January 20, 2006 at 6:23 pm
    [Chris Zwar] “Just as an aside, I find the quality of AE’s compound blur to be pretty poor when compared to 3rd party compound blurs. The Pinnacle one (which comes with Composite Wizard) gives a MUCH better result, and if there’s a Tinderbox, Boris or Saphire equivalent then I’m sure the difference will be just as noticable.”
    Also, our Gaussian Blur in our SmoothKit ($89.95) has a true compound blur, and not the box-blur equivalent of AE’s. Note that there are many other features of SmoothKit: blur without blurring over details, per-pixel directional blur, staircase step reduction, etc.
    You can see more here (including the reason why you want our compound blur over AE’s): https://www.revisionfx.com/smok.htm
    Cheers,
    Pete Litwinowicz
  • Roger Burton
    January 21, 2006 at 11:14 am
    Thanks all …..
