Activity Forums Adobe Premiere Pro Color correction
  • Color correction
    Posted by Karen Lee on March 1, 2020 at 4:17 pm
    Hi, I’m learning the basics and would appreciate recommendations on how to improve this clip. If it matters, it’s from a Sony NXCAM. It looks pretty hot but if I back off the whites / highlights, the Luma waveform indicates less than full dynamic range. I’m new to this so have not applied separate color balance to lows mids and highs. Top is the raw clip, latest is at the bottom.
    edited to add, this is the latest iteration
    a little further work…
    Shane Ross replied 6 years, 6 months ago 4 Members · 3 Replies
  • Chris Wright
    March 1, 2020 at 8:32 pm
    i know there’s no official setting for diffuse white(non-HDR), but many people recommend 10% less than absolute reference white to be reserved for specular. I personally don’t go above 90 IRE for regular whites. If you want to give the actor a different dynamic range than the overall look, you will need to mask their skin tones as a secondary correction.
  • Tero Ahlfors
    March 2, 2020 at 7:10 am
    She looks really pale and sickly green in the graded version. Unless that’s the point you’re trying to make with the grade.
  • Shane Ross
    March 2, 2020 at 7:06 pm
    I have to agree. The before image is a much better color. I’d perhaps tweak the blacks and highlights to lessen the curve to make the image pop more, but it looks more natural then the after ones.
    Shane
    Little Frog Post
