Activity › Forums › Maxon Cinema 4D › Cinema 4d R16 GUI bug
Kouraib Abdmalek
October 21, 2023 at 7:27 amHi Anastasiia,
Thank you for noticing that the problem occurred after installing Sonoma. This makes us certain that the reason is an overlap in the system files between Cinema 4d and another application.
Have you tried running the program as an administrator? Maybe it will work for you. You can do that by following steps:
1. Open the app that you want to run as an administrator.
2. Right-click (or Control-click) the app icon, then choose Open from the shortcut menu.
3. Click Open.
4. The app is now running as an administrator.
hope that will help
Rav Norodom
March 9, 2024 at 4:16 amI found a solution: I installed Parallel Desktop on Sonoma. Then installed Yosemite (MacOS 10.10.5) inside Parallel Desktop and next is Cinema 4D R16. It works inside virtual desktop and it runs very fast also.
Kouraib Abdmalek
March 9, 2024 at 8:09 amHi Rav,
Thank you very much for sharing that with us! I hope it will be useful to André and Anastasia.
