CineForm Aspect HD?
I’ve been playing with AspectHD and some test footage,
for a little while, but I just got my P2 card and
started really test driving the flow:My impression so far is that this is buggy and convoluted.
1) HDlink is very tempermental crashing without warning
if settings are exactly perfect.
2) Color/frame size/brightness change during previewing
in Premiere. The FAQ suggestion doesn’t fix the issue,
but does help and it is so old that it doesn’t match the
current Nvidia driver software so experimentation is
necessary.
3) The output to DVD from a CineForm HD project is terrible.
The conversion from 24p to 29.97 lower field, PAR=1.2
produces a file, that Premiere always thinks is a 0.9 PAR.
Using the interpret footage works for the aspect ratio, but then the red render bar pops up in the timeline.
In the one test, there were obvious field errors
as a wall edge would bounce back and forth like it was
a upper fields first file during a pan. Finally the color
of the DVD video wasn’t the same as the original AVI
produced by HDLink.I was really hoping for a nice workflow because I’ve
heard good things about it. Am I missing something?The goal is to film 720pN24, convert with HDlink to
AVIs with 1280×720(1.0). Bring this in to PPro CS3,
edit, color correct, and output to DVD. According
to the FAQs an export movie must be done before
using Adobe media encoder. Therefore I created a second
project that is a Widescreen DV project and imported
the exported AVI. Then I used this project to run
Adobe Media Encoder to generate the MPEG-DVD files.Does this sound reasonable for the AspectHD product?
MBW
