Activity Forums Apple Final Cut Pro Legacy Capturing and logging high frame rate video (in FCP 4.5 HD)
  • Capturing and logging high frame rate video (in FCP 4.5 HD)
    Posted by Antonbradley on March 5, 2007 at 10:31 am
    Hi there,
    I need some help in capturing and logging high frame rate video in a PAL (25 fps) project.
    It will be for a music video which I want certain scenes to be in high definition slow motion (without any
    Antonbradley replied 19 years, 5 months ago 2 Members · 2 Replies
  • Rafael Amador
    March 5, 2007 at 11:26 am
    Hi Anton< your misstaking "frame-rate" with "shutter speed". If you film standar PAL you allways get 25 images per second (25 frames or 50 fields that is the same in the interlaced world). To make a clean slow-motion you need to set the "Shuter speed' of your camara at a higher speed of the normal 50fps. You get the same nunber of images per second, but these images have less movement-blur. Is the same than when you rise the speed in a normal foto-camara. So don't look for nothing in FC. Look for the "shutter" in your camara. Cheers, Rafael
  • Antonbradley
    March 6, 2007 at 6:44 am
    Thanks guys,
    Dave – Do you have any names for the plugins ? (that can create intermediate frames)
    Thanks and Rgds,
    Anton
