Activity Forums Apple Final Cut Pro Legacy Captured Footage to Seagate Firewire Drive Has Gray Pixilated Flashes
  • Captured Footage to Seagate Firewire Drive Has Gray Pixilated Flashes
    Posted by Howie Young on August 5, 2007 at 1:58 am
    Greetings,
    I captured some footage to an external Seagate 300GB Firewire / USB 2.0 drive. When I play my footage through FCP large gray pixilated square areas intermittently flash on the screen and appear throughout each clip in the canvas window.
    When I play the same captured footage through QT the file appears clear, however, it is now jerky. It plays and stops and plays and stops for the duration of the clip
    My footage captures and plays fine to my internal media hard drives.
    What is causing the gray pixilated flashes?
    How do I make it stop?
    Why is this only happening when I capture to a FireWire Drive?
    Are Seagate 300GB Firewire / USB 2.0 brand drives not recommended for FCP video captures?
    I’d appreciate any insight into this troubling matter.
    Howie
    John Pale replied 19 years, 1 month ago 5 Members · 6 Replies
  • Walter Biscardi
    August 5, 2007 at 2:01 am
    [Howie]
    I captured some footage to an external Seagate 300GB Firewire / USB 2.0 drive”
    You can’t use a USB drive with FCP. Has to be at least FW400. USB has high burst speeds but do not maintain proper throughput for capturing / editing video.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Howie Young
    August 5, 2007 at 2:10 am
    Walter
    Thanks for the quick reply. I am capturing via firewire. My Seagate instruction book indicates the transfer rate for this drive is 400 Mbits/sec. Is this different than FW400?
    Howie
  • Deleted User
    August 5, 2007 at 2:45 am
    Hello Howie,
    Please post a screengrab of the grey flashs, you are experiencing. It could be a slow drive which can not keep up with the throughput of the editing.
    Leo Baker
    Post Production
    Sync Films
    United Kingdom
    http://www.syncfilms.com
  • Howie Young
    August 5, 2007 at 2:58 am
    Hi Leo
    How do I peform a screen grab while the footage is playing?
    Once taken, where should I post the image?
    Howie
  • Steve Eisen
    August 6, 2007 at 2:27 am
    Restart your compter and see if the problem goes away.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • John Pale
    August 6, 2007 at 6:16 am
    Re-read Walters posting.
    USB 2 drives do not have the SUSTAINED throughput necessary for use with FCP, though their burst rate equals or exceeds that of FW400. Its the USB 2 interface thats the problem, not the drive (FW and USB 2 use the same drives)
    This is likely to be the source of your problem.
