Activity Forums Apple Final Cut Pro Legacy Capture Question
  • Capture Question
    Posted by Michael Allen on August 10, 2009 at 6:38 pm
    I am capturing 1080 (24p native) from a Sony Z5u to ProRes 422 using a Kona LHI with the HDMI input. The kona control panel says that I am really getting 1080 60i in through HDMI. If I look at the bin information it indicates that the files are interlaced with upper field first. Should I change the bin field dominance to none or progressive or should I leave it upper field first? I guess the Z5u is doing a hardware conversion on playback. Is this a good workflow? Should I capture this footage another way?
    Mike
    Lee Hoffman replied 16 years, 3 months ago 3 Members · 2 Replies
  • Gary Adcock
    August 10, 2009 at 7:40 pm
    [Mike Allen] “apturing 1080 (24p native) from a Sony Z5u to ProRes 422 using a Kona LHI with the HDMI input. The kona control panel says that I am really getting 1080 60i in through HDMI.”
    what’s the issue?
    Native recording is only supported via the CF cards, and you would not use HDMI for that data transfer.
    If you are shooting on videotape it is still 24/ 60i and that the HDMI in this camera is v1.2 which does not support 24fps capture.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Check out
    https://www.aja.com/kiprotour/
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Lee Hoffman
    June 9, 2010 at 10:59 pm
    Hey Gary-On this note maybe you can help-this is wierd. I’ve got a Z5-U and have been capturing HDV footage with no problem for over a year using FCP 6.0 on an older Power PC MAC tower-duel G5-running 10.4.11, out of the camera into firewire 400 with these A/V settings:
    Sequence Preset: HDV-1080/60
    Capture Preset: HDV
    Device Control Preset: HDV Firewire
    Video Playback: Digital Cinema Desktop Preview-Main
    Audio-Default
    Now here’s the wierd part: I’m trying to capture on my new MacBook Pro-using Snow Leopard. I’m just looping the camera into the Firewire 400 connection through my external drive, then out to the laptop through the FW800 connection. Tested a capture using IMovie to check the connection and that sees it just fine, but with the EXACT same A/V settings, FCP on my laptop says the device is not connected. I’ve tried every other sensible Device Control Preset in the menu-including the Sony HDV presets-no dice. Nothing works-This baffles the hell out of me.
    Is it some Firmware or codec issue with SnoLeopard, or am I missing something stupid? Please help. Lee
