Activity › Forums › Apple Final Cut Pro Legacy › Capture HDV as DVCproHD with Kona LH and firewire control
  • Capture HDV as DVCproHD with Kona LH and firewire control
    Posted by Erik Naso on March 6, 2008 at 4:08 pm
    I am trying to capture HDV as DVCPROHD with my XH-A1 but cant seem to get the camera and Final cut 6 settings to work together. In FCP 5 I used to be able to have deck control via firewire while the cameras was hooked up to the Kona LH via component inputs. Now I can capture as DVCPROHD but the deck control wont work so no batch capture. I really want to batch capture. I did try the HDV capture as Prores and that worked well but I would like the option of batching and I dont think I can do that with prores. Any suggestions would be greatly appreciated.
    Erik
    Erik Naso replied 18 years, 6 months ago 6 Members · 15 Replies
  • 15 Replies
  • David Roth weiss
    March 6, 2008 at 4:30 pm
    [Erik N] “I did try the HDV capture as Prores and that worked well but I would like the option of batching and I dont think I can do that with prores.”
    Capturing HDV to Pro Res via firewire captures every take on a tape from camera start to camera stop on each tape, that sure seems like batch capture. Of course logging muct be done after the fact, but that’s no big deal.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Erik Naso
    March 6, 2008 at 4:55 pm
    Your right. I want to log and capture. Sorry about the wrong description. It would help if I can ask the question right. I think I need more sleep.
  • David Mcgiffert
    March 6, 2008 at 5:03 pm
    Here Erik,
    Take two of these and get some well deserved rest.
    We all know what it’s like…
    All the best,
    David
  • Jerry Alto
    March 6, 2008 at 5:29 pm
    Erik- To get your machine control you need to open the log and capture window and select the Capture Settings tab and select your machine control there.
    The normal Audio/Video settings won’t let you proceed.
    Once you have have everything working right make an Easy Setup.
    Hope this helps.
    Jerry
    G5 Dual 3GB Ram
    FCP5 Studio
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
  • Erik Naso
    March 6, 2008 at 5:51 pm
    Thanks. I will try that again. I was in easy setup using the firewire settings. I tryed all of them with no luck so went to log and capture and changed the capture setting to firewire. I did try all the available firewire settings but none worked for my XH-A1.
  • Tim Allison
    March 6, 2008 at 7:09 pm
    I’m confused. ProRes422 is just a codec, just like DVCproHD. How come you can batch digitize with one, but not the other?
    I don’t have a Kona LH, but we do have a Kona 3 and an Io-HD. Select ProRes or DVCproHD in the Easy Setup menu. After you do this, you will probably need to go the Audio/Video settings, and change machine control to Firewire. That always works for me.
  • Michael Gissing
    March 6, 2008 at 9:22 pm
    I used to capture from a Canon H1 via HD SDI uncompressed using firewire control. The camera had to be set to downconvert to DV via firewire and then machine control worked in a custom setup.
    That said, transcoding to DVCPro100HD via component inputs is not a good workflow compared to straight ingest as HDV and setting render to ProRes. You don’t want the double hit of component conversion and transcoding to Pro100. Messy workflow and technically more of a drop than HDV in and ProRes render.
    I am happily doing that with a 2.5 G5. Personally, I can’t see any point in considering DVCPro 100HD unless it is also your camera format. I don’t see a role for it in HDV particularly since ProRes.
  • Erik Naso
    March 6, 2008 at 9:56 pm
    I want to do log and capture. Mainly for safety reasons. If my drive dies then I will be able to rebiuld the project and relink the video to my sequence. Batching the whole tape in HDV to prores wont give me that option. Final Cut wont log and capture HDV to Prores. I am working on a training DVD series that has several hours of HDV. If the only way to achieve my goal is to log and capture in HDV and render in prores then I will go that way.
    Thanks.
    Erik
  • Michael Gissing
    March 6, 2008 at 10:08 pm
    [Erik N] “If the only way to achieve my goal is to log and capture in HDV and render in prores then I will go that way.”
    The transcoding is the same and it uses less drive space than going to ProRes on capture.
    That said, there are some that don’t like editing in HDV. I am recapturing and onlining documentaries and I have not found issues working with the HDV in via firewire and ProRes render workflow.
  • Erik Naso
    March 6, 2008 at 11:26 pm
    Thanks for the info. I think I need to reevaluate my work flow. At my day job I use Avid with standard def only. My home studio is Final Cut. I am not as savvy with Final Cut yet but getting better and to honest the HD thing is giving me a headache. When I finally come to a solid work flow with HDV I know it will be much easier just not their yet.
