Activity › Forums › Adobe Premiere Pro › Can’t hear audio in timeline, but meters indicate we have sound!?
  • Can’t hear audio in timeline, but meters indicate we have sound!?
    Posted by Jimmy Brunger on April 25, 2012 at 1:52 pm
    Hi all,
    Quick one I’m scratching my head on…all of a sudden I now can’t hear any audio when I play ANY clip in ANY timeline, although I can when played in source window. I’m getting responses from tall the meters, but just no sound via headphones or Mac speakers.
    Tried adjusting all combinations of settings with BMD prefs, PPro prefs, removed Perian, updated BMD drivers, switched GPU accel on and off…no joy.
    Anyone had this similar problem? My specs are below for ref. I’m running CS5.5.2 and BMD driver 9.5 (previously 9.2.1)
    Cheers guys,
    Jim.
    Production Premium CS5.5 – Mocha v1.5
    MacPro 3,1 8-core 3.2GHz / 32GB RAM / NVidia Quadro 4000 / OSX 10.6.8
    Decklink Extreme+ 3D / 3TB RAID-0 local / 6TB XServe + United Digital RAID on 10GbE
    Chris Dennett replied 11 years, 1 month ago 8 Members · 14 Replies
  • 14 Replies
  • Ryan Holmes
    April 25, 2012 at 3:02 pm
    Are your speakers on?! 😉 Kidding…
    I have this problem from time to time with Premiere. My only solution has been to restart PPro or reboot the computer.
    Ryan Holmes
    http://www.ryanholmes.me
    vimeo.com/ryanholmes
  • Jimmy Brunger
    April 25, 2012 at 3:12 pm
    Very good! 😉
    Yeah, tried restart PP and rebooted mac twice and still no joy…I’ve taken to importing sequence into After Effects to edit via RAM Preview! Not ideal..but short-term fix to get this thing delivered.
    Anymore ideas guys? I’ll need to fix it soon!
    Cheers,
    Jim
  • Jason Diebler
    April 25, 2012 at 3:25 pm
    We’ve seen some issues like that as well, recently with footage that came from Final Cut (live capture) and also from some aiff files. Our solution was to export the audio as a wav file from QT Pro and import that, and all worked nicely after that. Not ideal, but it kept us moving forward.
  • Tero Ahlfors
    April 25, 2012 at 3:31 pm
    If you’ve made a Blackmagic sequence the audio will play back through the I/O. Check your Audio Output Mapping preferences.
  • Jimmy Brunger
    April 25, 2012 at 4:32 pm
    Hi Guys,
    Thanks for responses. Yes, its a BMD sequence, but not using the decklink to output any audio, just to capture it via embedded SDI. I’ve got mapping prefs set to default headphones, but just not taking for some reason.
    Also, it’s doing this no matter what clip I throw in a timeline…by that captured uncompressed QTs via the decklink, exported QTs of various flavours from AE or QT Pro and also tried some MPEGs, WMVs, MP3s and straight WAVs – nothing!
    Yeessh.
  • Tero Ahlfors
    April 25, 2012 at 4:57 pm
    Have you tried making a non-Blackmagic sequence?
  • Jimmy Brunger
    April 25, 2012 at 5:21 pm
    A-ha! Yes, that’s done it!
    However, I still don’t understand why a BMD sequence suddenly has this problem and I guess I will still need to fix as this is our native mastering format.
    Thanks Tero – I guess next stop is Blackmagic support!
  • Tero Ahlfors
    April 25, 2012 at 5:22 pm
    I had the same exact problem. It seems to be that if youre playing back a Blackmagic sequence it wants to put the video and audio through the I/O no matter what the settings.
  • Vince Becquiot
    April 25, 2012 at 5:46 pm
    You may also have to check your OS preferences and change the audio output there.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Jimmy Brunger
    April 25, 2012 at 9:54 pm
    The strange thing is that editing in BMD sequences has worked fine for months and I never have the audio output routed through the card, in the OS or in the PPro prefs…so I just don’t understand why it’s suddenly started doing this!
    Only thing I can think of is that when I updated BMD driver last week to 9.2.1 (then subsequently 9.5 today) then it introduced the problem. I’d been on 8.0 for months and worked fine, but then had a HD capture problem last week (which bizarrely righted itself for no reason the other day!) and started updating driver to try to fix. Also jumped from CS5.5.0 to 5.5.2 which didn’t appear to help at the time.
    I’ll go back to v8 BMD driver and report back if this helps. Unfortunately I don’t think I can downgrade back to 5.5.0 without completely reinstalling can I?
    Cheers,
    Jim
