Activity › Forums › Adobe Premiere Pro › Can’t hear audio in timeline, but meters indicate we have sound!?
  • Bob Dix
    April 26, 2012 at 11:04 pm
    have you turned your speakers on ?
    Freelance Imaging & Video
    AUSTRALIA
  • Jimmy Brunger
    April 27, 2012 at 9:03 am
    Good gag Bob, but someone’s already beaten you to it above…. 😉
    Production Premium CS5.5 – Mocha v1.5
    MacPro 3,1 8-core 3.2GHz / 32GB RAM / NVidia Quadro 4000 / OSX 10.6.8
    Decklink Extreme+ 3D / 3TB RAID-0 local / 6TB XServe + United Digital RAID on 10GbE
  • Razvan Amarandei
    July 22, 2012 at 2:59 pm
    I just had this same problem and found your thread while looking for solutions. Don’t know if you’ve solved it yet, but I finally figured out what was causing this behavior for me. If you right-click on a sequence and go to sequence settings, the first entry there is “Editing mode”. go to playback settings / “Audio Output” tab and check “Use system sound card”. restart Premiere… and should work.. :),
    razvan
    THX,
    Razvan
  • Chris Dennett
    August 23, 2015 at 10:16 am
    I had the same issue (or at least an issue with the same symptoms) in Premiere Pro CC. For me I fixed it by selecting a different audio hardware default output (see screenshot).
    Edit (top menu) > Preferences > Audio Hardware
    I had to select speakers rather than the default to get it to work.
Page 2 of 2
