Activity Forums Canon Cameras Canon GL2 and lavaliere microphones for it
  • Canon GL2 and lavaliere microphones for it
    Posted by John Reynolds on April 28, 2009 at 8:35 pm
    I am currently using a Canon GL2 for my mid-range productions and I am looking to use a lavaliere microphone for it. Can any of you pro’s here in this forum recommend a decent mid-range lavaliere microphone best suited for this video camera? And what to look out for on this particular camera. I’m familiar with the ATT settings and the fact that I will be going from an XLR to mini plug hookup. Thanks
    Judy Gelles replied 16 years, 10 months ago 4 Members · 6 Replies
  • Don Greening
    April 28, 2009 at 11:43 pm
    This model of Sennheiser wireless will work well with your camera and is a low to mid-level price range. It comes with a wireless receiver to mini-plug (3/8″) adapter for the side of your GL2. Keep in mind that using the alternate mini-plug connection on the camera will disable the on board stereo mic. Don’t use the camera’s Mic ATT setting with the Sennheiser setup – just the regular mic setting will be fine and adjust the wireless signal accordingly.
    https://www.sennheiser.com/sennheiser/home_en.nsf/root/professional_wireless-microphone-systems_broadcast-eng-film_ew-100-series_021418?Open&row=z
    – Don
  • John Reynolds
    April 29, 2009 at 12:33 am
    Thank you so much Don for your reply. I’ll check the link out. Really appreciate your help. And yes I want the stereo on board mic disabled. I don’t like it anyways. 🙂
    Thanks again!
    John
  • Ralph Hajik
    May 10, 2009 at 5:44 pm
    Hi Don,
    I have the set up that your presently talking about with one lav, one transmitter and one receiver with the beachtek adapter. When using a second lav, what exactly do you need to record lav #1 and lav #2 when your doing field work as in weddings? Can both lavs be on the same frequency or are they on separate frequencies? I never used 2 lavs together before, that why I ask.
    Ralph Hajik
  • Don Greening
    May 10, 2009 at 6:15 pm
    [Ralph Hajik] “Can both lavs be on the same frequency or are they on separate frequencies? I never used 2 lavs together before, that why I ask. “
    Hi Ralph,
    As far as the Sennheiser EW100 ENG systems are concerned, each lav has to have its own transmitter and receiver. These ‘entry level’ systems don’t have the capacity to receive 2 separate frequencies like some of the higher end systems do.
    – Don
  • Ralph Hajik
    May 11, 2009 at 2:14 am
    Hi Don,
    Thanks for yout informatiom.
    Ralph
  • Judy Gelles
    June 25, 2009 at 2:50 am
    I have a Canon GL2. Is it possible to use a wireless and shotgun mic system at the same tim?
    I tried, and I think I just got the shotgun and not the wireless. Is there a setting on the camera to choose the type of microphone you are using? I think the shotgun cancelled out the wireless.
    Judy
