Cannot drag audio files to timeline in Sony Vegas Pro 8
John Rofrano replied 15 years, 6 months ago 6 Members · 26 Replies
Marcel Aguiar
November 26, 2009 at 6:45 pmEvery song on my iTunes is from a cd that I loaded to my iTunes… Even these ones are having problems.
Bob Peterson
November 27, 2009 at 12:44 amIn that case, get the music directly from the CD. Windows Media Player can do that job, and I’m sure there are many, many other ways to extract audio from a CD. Sound Forge, for example, can easily extract all the tracks from a CD.
Both of these options will deliver much higher quality audio, and Vegas will work with them.
John Rofrano
November 27, 2009 at 11:35 pm> is there anyway to not have to convert the music to mp3 every time that I want to use music?
Just to follow up on the answer to this question. The solution is not use Apple’s proprietary audio format to begin with. Especially if you import your music from CD. Change your defaults in iTunes to import CD’s as MP3 and keep all of your music library as MP3 and you will never be bothered by Apple’s proprietary audio format again.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
John Rofrano
November 27, 2009 at 11:47 pm> Sure! You can bypass it by avoiding sites, like iTunes, which use DRM.
Actually, iTunes doesn’t use DRM anymore so you don’t have to avoid them. It’s only if you have previous purchases that had DRM do you need to worry. Apple also allows you to upgrade your existing purchases to DRM free versions for the difference in price (the DRM was $0.99 and the non-DRM is $1.30). I buy all of my music through iTunes.
~jr
Maire Connors
September 15, 2010 at 6:10 pmHey I just want to say I have the same problem with it but for a video file and the format is in avi and mp4.
Anyone help??
John Rofrano
September 15, 2010 at 11:10 pmWhenever you can’t drag and drop a file it is usually because you don’t have the proper codec installed. Use a utility like GSpot to determine what codec you need and then find that codec and install it.
~jr
Ashley Angel
March 4, 2011 at 2:29 amI have the same problem i unistalled it but before i did i fixed it and it worked and now i am having the same problem when dragging any clip to sony vegas it wont drag but the icon 0 with an / on then O appears. what to do??
John Rofrano
March 4, 2011 at 5:02 am[ashley angel] ” now i am having the same problem when dragging any clip to sony vegas it wont drag but the icon 0 with an / on then O appears. what to do??”
Did you try what I suggested with GSpot in the post you replied to? If so, what did you find out about the cocec?
~jr
