Activity Forums Apple Final Cut Pro Legacy Can You UnNest Something?
  • Can You UnNest Something?
    Posted by Brian Pitt on June 13, 2006 at 5:45 pm
    I made the mistake of nesting a bunch of clips so that I could put a timecode generator on them to pass back to a client for review. Once I got the list of edits, I cut the actual nested clips and put them together. Now I can’t seem to make any changes to the audio because all of my clips appear to be part of a nested sequence. Is there anyway to “unnest” these clips so that I can make individual changes to them without having to pull the source clip?
    Brian
    Brian Pitt replied 20 years, 3 months ago 3 Members · 4 Replies
  • Mark Maness
    June 13, 2006 at 6:40 pm
    Yeah…! Just double-click the nest and copy the clips to your timeline or a new timeline. And you do know that you can edit the audio inside of a nest, right?
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Brian Pitt
    June 13, 2006 at 7:08 pm
    yeah, I knew that. I just had so much footage inside the nest that it’s kind of a pain to go and locate each small section that needs to be tweaked. but thanks for the input!!!
    Brian
  • Massimo Croce
    June 14, 2006 at 11:35 am
    to unnest a sequence comand click on the nested sequence and drag on the timeline
  • Brian Pitt
    June 14, 2006 at 3:22 pm
    thank you sir.
