Activity › Forums › Apple Final Cut Pro Legacy › Can you trust FCP’s Title Safe
  • Can you trust FCP’s Title Safe
    Posted by Julian Clarke on August 4, 2006 at 7:54 pm
    I just came back from a QC session where we were looking at a titled 16:9 squeezed Digibeta master that I had generated in FCP 5. To my surprise some of my titles appeared to be out of title safe on the EQ system. When I come back and look at my project however, I am just on the line of title safe. So, my question is, is FCP’s title safe reliable? Should I be concerened here?
    Julian
    Walter Biscardi replied 20 years, 1 month ago 8 Members · 20 Replies
  • 20 Replies
  • Peter Wiggins
    August 4, 2006 at 8:17 pm
    FCP doesn’t do anamorphic title safe, use Digital Heavens answer
    https://www.digital-heaven.co.uk/fcplugins/dh_widesafe.php
    Peter
    Free Motion Templates
    https://www.peterwiggins.com
  • Dan Riley
    August 4, 2006 at 8:18 pm
    covered yesterday. scroll down a bit and read away.
    dr
  • Dan Riley
    August 4, 2006 at 8:26 pm
    ah, different problem. you’re not talking subjective.
    never mind.
    dr
  • Kevin Monahan
    August 4, 2006 at 8:33 pm
    Were you not monitoring external video or what? Titles out of safe range is one of the big dangers of not monitoring output on a 16:9 capable monitor.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Julian Clarke
    August 4, 2006 at 8:39 pm
    Yes, I was monitoring on a 16:9 monitor and the titles looked fine. But I think title safe, usually ers on the side of safety, so this didn’t necessarily mean that I was not outside “safe”.
  • Shane Ross
    August 4, 2006 at 9:05 pm
    [Peter Wiggins] “FCP doesn’t do anamorphic title safe, use Digital Heavens answer”
    Then why do I see title safe and TV safe areas in my DVCPRO HD 16:9 sequence? Isn’t Digital Heaven’s solution how to get 4:3 title safe areas into a 16:9 project?
    Or is that what we are talking about here?
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Kevin Monahan
    August 4, 2006 at 9:10 pm
    OH, you were monitoring and the titles were still out of safe on another system? Hmm…that’s kinda scary. I’m gonna look into getting that DH plug then. You can’t have stuff like that happening in the online.
    Kevin Monahan
    fcpworld.com
    Pres. SF Cutters
  • Dean Sensui
    August 4, 2006 at 9:11 pm
    FCP’s “Title safe” is well within the “action safe” area so if your titles were on the verge of going off-screen (if that’s what you meant) then the system you were watching it on must have a lot of underscan.
    Or else perhaps the system that was displaying the program has much stricter standards for what they feel is “title safe”.
    In the limited amount of widescreen things I’ve done so far, I hadn’t run into a problem where titles have threatened to go out of bounds.
    Dean Sensui — http://www.HawaiiGoesFishing.com
  • Shane Ross
    August 4, 2006 at 9:18 pm
    I sent off stills of my titles to my broadcaster so they could QC the positioning and they all passed.
    You are using the INNER square for your title guides, right?
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Julian Clarke
    August 4, 2006 at 9:21 pm
    My titles do not look like they are on the verge of going offscreen… they look fine. I’m watching them on a very ordinary Sony PVM-20MRU with a 16:9 button. When I was in QC session they had a series of guides that showed up on screen showing there title safe, where I found my titles were often venturing outside their guides. Again it looked fine on there monitor, but OUTSIDE safe. From what I understand title safe, is mostly a conservative estimate relevant to ancient televisions. Everything I’ve been monitoring this show on, has been made this century. I’m just trying to be diligent in delivering a master here that will meet everyone’s standards and expectations. It was somewhat alarming to have FCP’s title safe not match to the title safe in the EQ system.
