Activity Forums Apple Final Cut Pro Legacy Can you stretch without blowing up?
  • Can you stretch without blowing up?
    Posted by Scott Fields on March 3, 2010 at 8:15 pm
    Is there a filter that will allow me to stretch my 4X3 footage to fill a 16X9 frame WITHOUT blowing it up?
    I’m looking for something like the Justify mode Panasonic monitors use to fill the screen where they stretch the left and right sides of the image leaving the center mostly intact.
    Scott Fields replied 16 years, 2 months ago 4 Members · 5 Replies
  • Brian Pitt
    March 3, 2010 at 8:53 pm
    If you want to convert 4×3 footage into 16×9, you have 2 options. You can crop off the top and bottom, or you can stretch it. There is no way to keep all of your information and convert it to 16×9 without distorting it.
    Brian
  • Scott Fields
    March 3, 2010 at 8:57 pm
    I wasn’t clear before: I fully expect to distort it– I just didn’t want to use the only option I’m familiar with: blowing up the image and cropping the top and bottom. I’m looking for a solution that simply stretches the left and right sides to fill the 16X9 frame. I don’t see a filter in FCP that does this.
    Ideally, a “smart” stretch that leaves the center of the image more or less intact.
  • Michael Gissing
    March 3, 2010 at 9:05 pm
    Andy Mees to the rescue
    https://web.mac.com/andymees/Free_and_Easy/main/Entries/2008/3/3_Andy%E2%80%99s_Elastic_Aspect.html
    Another great free plugin – thanks Andy!
  • Rich Rubasch
    March 4, 2010 at 2:49 am
    What I do is in the Distort box under the motion tab simply enter the 1/2 width value of the 16:9 comp into the four Upper Left/right etc. You are essentially pulling the four corners over to lock to the corner of your 16:9 frame.
    Rich Rubasch
    Tilt Media Inc.
    Video Production and Post
    Owner/President/Editor/Designer/Animator
    https://www.tiltmedia.com
  • Scott Fields
    March 4, 2010 at 2:51 am
    Fantastic solutions!
    Thank you everyone!
