Can I change my project from 4:3 to widescreen without starting a new project?
Hey guys, this is my first post in these forums, so please be gentle. If this is the wrong place please do let me know were I should post.
I started a project in what I now believe is 4:3 ratio (NTSC DV (720×480, 29.970 fps)).
So I added all my footage (which is widescreen), edited loads and worked on it for ages. But now I realized it always renders in 4:3 because my project is in 4:3! I really want to make a widescreen vid.
Is there any way of rendering from this project so that it makes a widescreen vid?
Or is there any way of now changing the project settings to widescreen?Or is the only way to start a new project (NTSC DV Widescreen (720×480, 29.970 fps)) and then do everything all over again?
I hope my question is clear
Thanks in advance
Paavo
