Activity › Forums › Apple Final Cut Pro Legacy › Can I Capture four Seprate Channel in FCP 5
Posted by Sulaman Hameed on September 19, 2006 at 2:59 pmHello,
Anyone tell me Can I Capture Or Export four Seprate Channel in FCP 5.
Plz Help me outSulaman Hameed
Sulaman Hameed replied 19 years, 11 months ago 3 Members · 17 Replies -
Mark Maness
September 19, 2006 at 3:15 pmYes! Just set your audio outputs to Dual Mono and change it to four channels.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com -
Matt Callac
September 19, 2006 at 3:58 pmTo capture 4 channels in the log and capture window under the clip settings tab make sure you enable press the switches for channels 3 and 4.
-mattyc
Sulaman Hameed
September 19, 2006 at 4:03 pmWayne Carey thanx for your reply but still I am not understand. My Question still that when I Export FCP timeline file can 4 seprate channell in one file & can I capture 4 audio seprate channell. Plz Clearly tell me..
Sulaman Hameed -
Matt Callac
September 19, 2006 at 4:15 pmPress cmd 0 (apple key + the zero key) to bring up the sequence settings for the sequence you want to have four seperate channels of audio. Then Click on the audio tab. From the pulldown menue select 4 outputs and click the dual mono selection on both pairs. This should give you four seperate channels for export or laying to tape.
-mattyc -
Mark Maness
September 19, 2006 at 4:24 pmOk…. Here’s what you’ll have to do.
To export four channels of audio: You have to change the Sequence Settings for your timeline. Select your sequence and right click (or go to your menu at the top of the screen and select Sequence – then Settings) and select “Settings…” Next, go to the Audio Outputs tab. Change your outputs to four. Now, you have four stereo outputs. Change the Stereo to Dual Mono and you’ll get four distinct audio channels. Click on Ok to close the window. Now, you can output you timeline any which way you want excpet to DV (which is two channels at 48k).
To capture four audio channels: First, your tape must have four seperate audio channels before you can capture four seperate audio channels. Select the Easy Setup you wish to use. Some setups are ONLY two channels, so it depends on what you are using. Next, go to you menu – Final Cut Pro-Audio/Video Settings. Look under the Capture Presets tab and click on “Edit…” Depending on your capture card, it should be set to 48.000 kHz 24-bit 8-channels (the limit set by Quicktime). If it is… great! Next, go to Log and Capture under the menu – File. Once your Log and Capture window open, go to the Clip Settings tab. There you can select which audio channels to capture by clicking on the little speakers. The little button to the left is the Stereo / Dual Mono button. If you click it, it will change to which ever you want (its self explanitory). After all of this, just log and capture.
I hope this helps.
Wayne Carey
Schazam Productions
Sulaman Hameed
September 20, 2006 at 3:33 pmThanx…. Wayne Carey U give me easyiest way to do this …. thanx again ….
U suggest me an Audio Card that support 8 channel … but I have built In Sound Card Burr Brown PCM3052 in G5 they support only 2 channel. Any suggessition plz tell me…
Sulaman Hameed
Senior Non Linear Editor
Geo TV Netrwork
Pakistan -
Mark Maness
September 20, 2006 at 5:07 pmWhat video capture card do you have installed in your computer? AJA or Blackmagic? Both support eight channels of audio input.
Wayne Carey
Schazam Productions
Sulaman Hameed
September 20, 2006 at 5:12 pmHello, Wayne Carey…
I have NVIDIA GeForce 6600LE. It is builtin in G5
Sulaman Hameed -
Sulaman Hameed
September 20, 2006 at 5:13 pmHello, Wayne Carey…
Sulaman Hameed -
Mark Maness
September 20, 2006 at 5:19 pm[sulaman Hameed] “I have NVIDIA GeForce 6600LE. It is builtin in G5”
Not that video card. The capture card. How are you getting video into your computer?
Wayne Carey
Schazam Productions
