Activity › Forums › Apple Final Cut Pro Legacy › Can I Capture four Seprate Channel in FCP 5
Sulaman Hameed replied 19 years, 11 months ago 3 Members · 17 Replies
Mark Maness
September 20, 2006 at 7:16 pmOk… that does present a problem.
Ok… Since you are using DV, I assume that you want to record four channels to DV and import a four channel DV tapes. I’m not sure about the DSR-11 but you can set your DSR-45 to 32k audio which will give you four tracks of audio to record and playback.
BUT here’s the problem. FCP will only use 2 channels of DV audio at a time. So…. doing four channels of DV (input & output) is not possible in FCP. Sorry.
One solution is to purchase an AJA IO and use it with a DSR-1500a with SDI outputs. Then you can use a custom preset to set your audio to four seperate channels. OR you could setup two different Easy Setups – one with channels 1 &2 and the other with channels 3 & 4 ONLY after your set your cameras and machines to 32k audio and then you capture your clips twice so that you get all four channels. But this will only get the audio in but not out.
I hope that sheds some light for you.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com -
Sulaman Hameed
September 21, 2006 at 9:10 amWayne Carey ….. Thanx very much U give me so much detail about tracks..
Thanx…..Sulaman Hameed
Sr. Non Linear Editor
sulaman_28@hotmail.com
Geo TV Network
Karachi, Pakistan -
Sulaman Hameed
September 21, 2006 at 9:15 amWayne Carey ….. Thanx very much U give me so much detail about tracks..
Geo TV Network
Karachi, Pakistan -
Sulaman Hameed
September 21, 2006 at 9:17 amWayne Carey ….. Thanx very much U give me so much detail about tracks..
Geo TV Network
Karachi, Pakistan -
Sulaman Hameed
September 21, 2006 at 9:27 amWayne Carey ….. Thanx very much U give me so much detail about tracks..
Geo TV Network
Karachi, Pakistan
