Activity Forums Storage & Archiving Calling Dr. BOB! formatted raid
  • Calling Dr. BOB! formatted raid
    Posted by Kevin Christopher on March 26, 2012 at 1:16 pm
    One of the vampires who works here formatted one of the raids last night. Luckily he stopped the moment he realized what went wrong. What is the best course of action for recovery?
    Mac OSX 10.6.8
    Arecca 1221X Card on a MAXX Digital EVO Box Raid 5
    8 WD 1TB Black drives
    He formatted it from disk utilities. Then turned everything off called me at 2:30 am and went home. So I am hopping there is not too much damage done. Well besides the fact he FORMATTED IT!
    RRRRRR!,
    Kevin
    Ed Stahr replied 14 years, 4 months ago 7 Members · 16 Replies
  • 16 Replies
  • Andrew Richards
    March 26, 2012 at 1:45 pm
    Try DiskWarrior and cross your fingers. If he really did just reformat the volume and immediately power down, then the data should still be there. Be prepared for the recovery attempt to take a very loooooooong time.
    Best,
    Andy
  • Steve Modica
    March 26, 2012 at 2:12 pm
    The early superblocks that layout the filesystem geometry are probably gone. So you’ll need a tool that’s smart enough to search past those to later superblock backups that might still have the old HFS geometry. Then whatever data is left can be recovered.
    If the inode table was completely destroyed you’re not going to have much luck. If you only lost some of the root inodes (that define the root directory etc), you may end up with a bunch of files in “lost+found” that need to be recovered.
    I’d consider a call with the Diskwarrior guys just to discuss whether diskwarrior can do what I described
    Steve
    Steve Modica
    CTO, Small Tree Communications
  • Kevin Christopher
    March 26, 2012 at 2:15 pm
    Thats a Negative. Disk warrior can only compare the backup Directory table to the primary. When you format both are destroyed. Theoretically I could rebuild the raid, because the parity info is not destroyed, but I need some confirmation on this. Data Rescue can see the data, but it has no Idea what the file names are.
    Kevin
  • Steve Modica
    March 26, 2012 at 2:29 pm
    The raid itself was not destroyed. You don’t have to rebuild that. This was a filesystem reformat (disk utility). So the RAID is happy (or should be except that he power cycled it without warning).
    So the main issue is superblocks.
    In the olden days, we could find a “good” superblock and run mkfs is a recovery mode pointing to that block. It would layout the filesystem again without touching the data itself. Then you could fsck or whatever.
    Steve
    Steve Modica
  • Kevin Christopher
    March 26, 2012 at 2:34 pm
    I have put my call into Disk Warrior and I am awaiting a response. I am going to wait until I can get a step by step method from somewhere. i don’t want to further damage it.
    Kevin
  • Matt Mullen
    March 26, 2012 at 2:50 pm
    You could try Data Rescue, I’ve had success in the past. You will need the space to recover to.
    https://www.prosofteng.com/products/data_rescue.php
  • Kevin Christopher
    March 26, 2012 at 2:54 pm
    I did a preliminary test with that, but It does not recover the file names. 8 TB of QT0001.mov. Blehh!!
    Kevin
  • David Gagne
    March 26, 2012 at 3:14 pm
    Purchase and use R-Studio. Works well to recover raids.
  • Kevin Christopher
    March 26, 2012 at 4:18 pm
    Still no magic bullet.
    Kevin
  • David Gagne
    March 26, 2012 at 5:50 pm
    Bummer.
