Activity Forums VEGAS Pro building my own computer….suggestions please
  • building my own computer….suggestions please
    Posted by Rhys Panero on February 24, 2009 at 12:34 am
    I am looking to build my own computer for the first time and am looking for equipment suggestions for Vegas Pro 8.0 or 8.1 My budget is around $2000.
    What….
    Case
    Motherboard
    CPU
    Operating System
    Hard Drives
    Memory
    Optical Drives
    and anything else you would reccomend.
    Thanks for your help
    John Frey replied 17 years, 6 months ago 4 Members · 12 Replies
  • 12 Replies
  • John Rofrano
    February 24, 2009 at 12:52 am
    The full specs of my system are on the PC Equipment page of my web site. A number of us built this same system a year ago and no one has complaints and it’s still a killer system that is solid as rock and so whisper quiet that I do voice overs sitting directly in front of it.
    If I had to build one today I would build an 8-core machine but that is definitely over your $2000 limit. Many people are building Intel i7 systems these days. They are said to be faster for tasks like video editing.
    My formula is simple. Buy an Intel motherboard with an Intel processor and memory that is listed on the Intel site as having been tested with the motherboard and you can’t go wrong. Your system will be solid as a rock.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Rhys Panero
    February 24, 2009 at 1:27 am
    What are your thoughts on the Intel i7 systems (920 or 940) vs the Intel Core 2 Quad Extreme.
  • John Rofrano
    February 24, 2009 at 4:22 am
    From what I’ve read the i7 systems process video faster than the Core 2 Quad that I have. If I was building another Quad system I would seriously look at the i7. I haven’t priced them out but if they are within your budget, I would go for one.
    ~jr
  • Neal Wingenbach
    February 24, 2009 at 6:50 am
    I logged on to ask this very same question. The issue I am having is that playing HDV video playback (Sony *m2ts files recorded at full HD with an SR12) is incredibly rough. This only happens within Vegas Platinum Pro so I am still wondering if I could tweak some settings within Vegas to fix this. But still, I am hoping that a new system will fix this.
    My current system has the following config:
    Dell Dimension 9100
    Pentium Dual Core (2Ghz)
    4 GB DDR2 RAM
    SATA2 hard drives – video and page file are on seperate drives
    NVidia 6800
    XP Pro Service Pack 3
    Question, do you think the above system config is underpowered to smoothly edit m2ts files?
  • John Frey
    February 24, 2009 at 7:05 am
    Prices are falling for components needed to put together a very fast edit workstation. I have built(3)edit workstations in the past 18 months now running Vista 64bit based upon Intel or Asus Motherboards, Intel Core 2 Duo or Quad Core processors, big power supplies, lots of cooling, and plenty of ram. These are gradually replacing older systems in our studios. I am now pricing/shopping for a 4th system. Intel iCore procs are very fast indeed, and the 920 version is reasonably priced. But, you will need a pricy motherboard and DDR3 ram to work with it, so plan on spending extra if you go that route. Some features on the newer, mboards to look for are HDMI, external Sata connectors, and soon, USB3. Check out NewEgg for reviews and pricing. Good luck!
    John D. Frey
    25 Year owner/operator of two California-based production studios.
    Digital West Video Productions of San Luis Obispo and Inland Images of Lake Elsinore
  • John Rofrano
    February 24, 2009 at 12:40 pm
    Yes, definitely. The Sony web site recommends a minimum of 2.8Ghz for editing HD. Also, if you really have a Pentium Dual Core and not the newer Core 2 Duo this is even worse because the older Dual Core technology performs poorly.
    Just so people don’t get confused when they read this, HDV is a 1440×1080 tape based format using miniDV tapes and MPEG-2 compression that plays very smoothly in Vegas on modern PC’s. Your SR12 shoots 1920×1080 AVCHD which is a tapeless format using AVC compression that even the most powerful PC’s today have some trouble with.
    ~jr
  • Rhys Panero
    February 24, 2009 at 2:49 pm
    What Intel Motherboard would you reccomend for the Intel i7 Core processor?
    Thanks again for the help!
  • John Rofrano
    February 24, 2009 at 3:44 pm
    There is only one from Intel right now and that’s the Intel DX58SO Extreme Series.
    ~jr
  • Rhys Panero
    February 25, 2009 at 12:19 am
    Ok thanks for all the help. I’m going for it….here is what I have in the cart at newegg…(please remember I’m a newbie at best so please bare with me)
    Motherboard..Intel DX58SO
    CPU………..Intel Core i7 920
    Memory ……Corsair XMS3 6GB(3x2GB) (max for the i7 Core..not sure?)
    Video Card…ASUS GeForce 9600GT 512MB
    Pwr Supply…SeaSonic M-12-600W ATX12V
    Optical Dr1…Pioneer 8XBlu-Ray DVD Burner model# BDR-203BKS
    Optical Dr2…Pioneer 20X DVD+-R Burner model# DVR-2910
    Oper. Sys…..Vista 64 Home Prem.
    Things I still need are…
    Tower……need ATX..I guess a Mid Tower should be fine ? (couldn’t find the Antec Lifestyle Sonata ll @NE)
    Hard Dr1…not sure what would work best with the above in the 600GB range
    Hard Dr2….700+GB range again not sure on best compatible
    What are thoughts on the above items…I guess i’ts all compatible?
    Any suggestions on the Case/Tower and Hard Drives?
    What else am I forgetting for the tower?
    Thanks again for the help. This is my first build and I want to get it right.
  • Neal Wingenbach
    February 25, 2009 at 1:32 am
    Thanks for the reply, John. I’ll be going as big as I can on the new system. Definitely, an Intel i7-940 with an ASUS MB. I don’t quite think I can go to dual socket as that’d probably break the bank.
    Neal
