Activity Forums Adobe After Effects brush strokes rendering in flash files
  • brush strokes rendering in flash files
    Posted by Hmburley3 on May 11, 2006 at 2:47 am
    i’m sure this is a stupid question but is there any way to get brush strokes effects to render once you save the compostion as a SWF of flash file? I’ve been using brush strokes which don’t render but achieve a very animated look as they change over time.
    If i can only use masks to substitute for the brush strokes, can they achieve the same animated qualities through the use of feathers, etc? or are there file extensions other than quicktime that will support effects such as brush strokes? thanks vey much,
    Hugh
    Hmburley3 replied 20 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
