Activity › Forums › Apple Final Cut Pro Legacy › Browser to Timeline Problem
  • Browser to Timeline Problem
    Posted by Eric Klassen on May 28, 2005 at 6:39 pm
    I have some animations I made in LiveType, imported them into the Browser and viewed them on the browser. The animations looked clean. I dragged them onto the timeline and moved the curser over them and part of the text became blurry (rather than fragmented for good playback). I compressed the timeline using Compressor 60 min high quality, and viewed the mpegs in DVD SP3. The blurriness was still there. Also, I layered some text over the animation from 3D Text and that became blurry as well.
    Why is the animation and text becoming blurry upon placing it onto the timeline? Is there some setting I’m just completely missing? I’m on the same settings I always use and have not had this problem before I am totally stumped.
    Kevin Monahan replied 21 years, 4 months ago 2 Members · 2 Replies
  • Eric Klassen
    May 28, 2005 at 7:33 pm
    So I’ve messing around with this and it seems that I can get the animation clips to appear clean in the viewer. When I dragged the clip over and put them into the timeline by overwriting, the 3D text paragraph stays clean…what? I don’t understand this…the text goes blurry if I just drag the clip onto the timeline and place it in it’s appropriate layer. So it appears that the entire LiveType animation layer will appear clean in the viewer, but as soon as it goes into the timeline, then it gets blurry. This is so wierd, I’ve used LT so many times, always without any problem at all, I don’t what this could be.
  • Kevin Monahan
    May 28, 2005 at 8:06 pm
    Eric,
    I hear you on this confusion. It actually happens a lot to people, and you’d see that too if you did a search on the word “blurry”. What is going on here? In the Viewer, you are seeing the LT animation in the Animation Codec, which is lossless. Once you place it into the timeline, it becomes a totally new beastie. It’s now in the DV-NTSC codec and compressed 5:1. Adding to this confusion is a little thing called RT Extreme, which is something you absolutely need to get your head wrapped around. RT Extreme allows you to preview more layers with effects on them to playback. Next on the list: the dizzying array of options to render your animation into the timeline’s codec. You have to make sure the correct options are checked off. Topping off this confusion is that I am guessing that you are not using a video monitor as you work. If you are judging your graphics and rendered fx on the Canvas only, well, you cannot see the true rendered quality of your fx. IOW, you don’t have a “functional FCP workstation”. You see, FCP is more than another computer app, it’s a system–you have to work with FCP set up properly to have a predictable and reliable experience while you’re editing. Rather than giving you a quick fix, it’s better that you understand what is actually going on here:
    First read this so you can understand how rendering works, you’ll need to know the difference between Safe RT and Unlimited RT and have the right properties checked off when you render your LT animation into the Sequence:
    https://www.kenstone.net/fcp_homepage/rendering_rt_fcp_4_balis.html
    What should you learn from that article?
