Activity Forums Adobe After Effects Broadcast Safe Adjustment Layer
  • Broadcast Safe Adjustment Layer
    Posted by Jake Abramson on July 3, 2007 at 7:14 pm
    I’m doing a project and this spec is part of the requirements
    “An adjustment layer must be used to make the final Broadcast Safe. Blacks must be set to 16 and whites to 236 (from 0 to 255 RGB).”
    Which filter would I use for this?
    Also, do you read this as that filter on every layer or to the entire comp (or does it matter?)
    Thanks.
    Simon Roughan replied 19 years, 2 months ago 4 Members · 3 Replies
  • Jimmy Brunger
    July 3, 2007 at 8:31 pm
    Put an adjustment layer on the top of your final render comp and apply levels and set blacks to 16 and whites to 235 (not 236!) Also check colour saturation – try broadcast safe colours effect to see if it keys out any illegal colours.
    *Production Studio Premium / *Combustion 3
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Roland DS-5 monitors / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0
  • Darby Edelen
    July 3, 2007 at 8:43 pm
    [jimmybee500] “Put an adjustment layer on the top of your final render comp and apply levels and set blacks to 16 and whites to 235 (not 236!)”
    To clarify, set your output blacks to 16 and your output whites to 235. The Adjustment Layer at the top of the stack will apply this to all of the underlying layers (which is what you want).
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Simon Roughan
    July 4, 2007 at 8:55 am
    Also, a good idea is to add a directional blur, 0 degrees and 0.5 pixel to this final adjustment layer. it takes away any flimmer in diagonal lines or text.
