Activity Forums Avid Media Composer Broadcast requirement
  • Broadcast requirement
    Posted by Dan Newton on April 21, 2009 at 5:04 pm
    Hey Guys
    Need some urgent help — I have been given the new format — from a television station — they will not use digi or sp for broadcast but mpeg 2
    now please fund below the exact requirements:-
    Dear All,
    Please be informed that henceforth all TV commercials to be aired on …. Television is not required in Digi Beta or Beta SP format: Kindly note  new material specs:
    File Format : Mpeg 2 or Mpeg 4
    Duration in seconds  : Multiples of 5 for eg: 10, 15, 20, 25 etc…
    Deadline for airing : 4 -5 working days after receipt of material
    There is no change in Material requirement for sponsorship tags. However, please note the same for your reference:
    5 sec mute mpeg ( in case of animation) or jpeg ( for static image). Mpeg size not to exceed 4 MB. Material to be sent by email
    Voiceover  format:
    David Braswell replied 17 years, 4 months ago 2 Members · 1 Reply
  • David Braswell
    April 21, 2009 at 7:58 pm
    Based on the dealings I’ve had in the broadcast world (local cable mostly) the list you were given is somewhat non-specific. Are those MPEG-2s program or transport stream? What bit rate? What sampling rate and format for the audio? You can export MP4s straight from the timeline. But I really think you need to try to talk with the tech guy at the station (sounds like a smallish station) and nail some of the specifics I mentioned earlier.
