Activity Forums Apple Final Cut Pro Legacy Brightness jumps at beginning/end of dissolves ?
  • Brightness jumps at beginning/end of dissolves ?
    Posted by Rj Miles on October 22, 2006 at 6:16 pm
    What causes brightness jumps/dips at the beginning & end of dissolves when exporting the sequence to a quicktime movie using the CURRENT SETTINGS?
    The rendered transitions look fine when played in the timeline. When the sequence is exported, the QT movie has a jump in brightness at the 1st frame and a dip in brightness at last frames of each dissolve.
    Exporting with “recompress all frames” on export or chosing the codec eliminates the jumps/dips. Of course these options are also much slower.
    Is there something I need to tweak?
    Steve Shadforth replied 15 years, 5 months ago 4 Members · 6 Replies
  • Kevin Monahan
    October 22, 2006 at 6:39 pm
    Never judge quality using QT Player unless you’ve enabled the High Quality flag.
    Go here:
    https://web.mac.com/sfcutters/iWeb/fcpworld/news/D4363B62-EFF5-4F30-B719-9A5E93AE4C92.html
    Come back and tell us if that worked for you.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Rj Miles
    October 22, 2006 at 7:30 pm
    Hi Kevin…
    Thanks for this tip. I learned about the high quality option when I 1st saw problems with imported DV footage when viewed in QT.
    The high quality is checked, and does not change the jump/dip artifact.
    I tried recompressing the problem exports in cleaner, to my online 320×240 review size, and the jumps/dips were also in these files as well.
    There definitely seems to be something bad happening when exporting with CURRENT SETTINGS and not recompressing all frames. 1st I thought maybe I had made a mistake in the alignment of lower layers and the higher layer dissolve transitions.
    For now, I’ll just recompress. However, I have a long format HDV projec/edit comping up and recompressing will be a major time hog. 🙁
  • Rj Miles
    October 22, 2006 at 7:45 pm
    Here is a link to a folder with the good/bad clips.
    https://www.blanca.com/test/
  • Bret Williams
    October 23, 2006 at 3:35 am
    What are your sequence video render settings? Are you rendering with RGB, White or Super White? It should be White.
  • Rj Miles
    October 23, 2006 at 3:48 am
    I tried both RGB and the normal YUV 8bit. I made sure I tossed the rendered reference files so they were rebuilt. Both produced the same artifacts.
    I never tried to change the WHITE setting which remains in the default WHITE setup.
    When I get a minute, I plan to try a new project with some DV and HDV footage, rather than strictly with AE rendered source files of the current project.
  • Steve Shadforth
    April 27, 2011 at 1:05 pm
    Change the base layer’s composite type to add, fixed it for me.
